Porsche Crest Door striker plate bolt (screw)
Can anyone tell what type of head the subject bolt has. Mine is neither Allen nor Phillips type and I need to adjust the position of the plate as the door is not shutting properly.
Thanks for any help.
Dean-Bilbao, Spain
Old 01-20-2004, 06:50 AM
I would rather be driving
jpnovak's Avatar
Hi Dean,
The bolts will be a 12 point socket commonly called a "triple-square". In the US local auto parts suppliers will carry the tools. If you can not find them locally, There are a few online places that sell them. Our host has them in the "tools" section.
Old 01-20-2004, 06:55 AM
Senior Member
Jdub's Avatar
Be sure that the door-side latch mechanism Philipps head screws are very tight. They thread into a captive nut inside that often breaks loose.
If you cannot get them to tighten, you will need to go into the door and hold the bolts from the inside. Use blue Loctite to hold everything in place. Keep in mind that no adjustment can be made with the doorside mechanism -- it is all in the plate you are working with.
Finally, check out the plastic roll that sits over the round section on the plate you are working with. It should be there and it should be snug.
Best of luck,
John
'78 Targa in Minerva Blue
Old 01-20-2004, 08:16 AM
CHILI's Avatar
As Dean said, they're pretty easy to find. And as long as there's no other problems, as John suggested, it's straight forward.
The best way to adjust (in and out) is to losen those bolts with the proper tool, until the plate can move around, but not too lose to where it's sloppy. Then gently close the door while holding the trigger in, so that it doesn't latch. Then gently push on the door handle until it the door edge lines up with the body to your liking. Then while continuing to hold the trigger in, gently open the door and tighten the plate where it is. I hold it slightly; pushing against it so it doesn't move while you're tightening the bolts.
Shut door as normal and open beer! Hehehe
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 01-20-2004, 09:51 AM
