This question is specific to the '86 Turbo, which has a different heating controller than the 911. With the heat control dial (knob between the seats) on my Turbo turned to zero, the footwell fans are on, but at their lowest speed setting. After tracing out the wiring in the controller,
If you have an '86 911 Turbo, can you check if yours is the same, Thanks in advance for any help! -Juan
www.ArtOfRoadRacing.com, Thunderhill, 30 Jan 2011 ArtOfRoadRacing@gmail.com SM #34, '04 GT3, '73 911s, '70 911 2.7L PRC Toyo Spec #11 |
Juan,
Mine are not on with the control knob set to 0. JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle |
This is normal. It seems that around 85/86 [correct me if I'm wrong] the factory began to see problems with the old design. The first problem was that the footwell blowers were not fused. So a change was made
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
Automotive Monomaniac
I've never noticed,
Let me go out
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
OK, now you've opened a can of worms!
With the key to "ignition" If I move the control to "1" or "2" or even "8" I hear the servo in the control unit spinning away for a moment, but I still don't hear a fan blower... is mine burnt out? Does it wait for the car to be warm? I don't think it is that smart... Now, if my car is on the highway,
Emission,
The small fan you hear by the ash tray is in the temperature sensor. You can ignore that sound. My follow up question for you ( If the fan never turns on, then you have another problem, likely a blown fuse, Thanks, -Juan
www.ArtOfRoadRacing.com, Thunderhill, 30 Jan 2011 ArtOfRoadRacing@gmail.com SM #34, '04 GT3, '73 911s, '70 911 2.7L PRC Toyo Spec #11 Last edited by logician; 03-21-2006 at 09:06 PM.. |
Juan,
I would assume that the heater isn't intelligent enough to wait for the car to be warm. In 1986, that would have been pretty advanced - most all cars would just blow cold air until the engine (or coolant) was warmed. Let me try mine again at the highest setting (defrost, I think) If it is the fuse, is it underhood or somewhere else? - Mike
Mike,
Thanks for checking it out. The system does have a temperature sensor at the flapper that I think is designed to keep from blowing cold air. So you might need to warm the car up to get the heating system to work completely. I belive there is a fuse in the trunk fuse box. Ron also pointed out that there may be an inline fuse as well, but that doesn't show up in my schematics. -Juan
www.ArtOfRoadRacing.com, Thunderhill, 30 Jan 2011 ArtOfRoadRacing@gmail.com SM #34, '04 GT3, '73 911s, '70 911 2.7L PRC Toyo Spec #11 Last edited by logician; 03-21-2006 at 09:07 PM.. |
Ron,
Do you think the fix from the factory was to leave the blowers running even with the heat off? That's what I am seeing. Also, I see that there is a microswitch that turns off the blowers when the flapper valve opens all the way -- full heat. Do you know if that is part of the same fix? -Juan
On my '86, the knob between the seats simply controls the amount of cool air that enters the system from the heater flapper boxes. The output correlates with the rpm of the car(fan blowing faster). The knob simply controls the degree of heat
Doug,
Your footwell blowers are not working. Check the fuse in the trunk. -Juan
Which fuse is it? All 21 up front look good,
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) Last edited by Emission; 03-21-2006 at 09:09 PM.. |
Emission,
The locations of the fuses are indicated on the fuse-box cover. Looking at my cover, -Juan
Yeah, it looks like you count from 1-21 starting from the rear (windshield). Mine all look good.
In the back, I removed the fuse cover Tomorrow I will drive her
I'm not sure if the inline fuse ever made it to the schematics. Yes, there is a sensor on the heat flapper
Help! Does anyone understand the footwell blower circuit? Footwell blower thread closed?
Juan,
My car runs the fans at low speed when the dial is in positions 1-7. Select 8 or 9 Hope this helps you, JR
The 10A in-line fuses were added to cars produced from April 23, 1986. The serial numbers for cars with fuses start with:
...910GS121913 ...911GS161516 ...916GS171278 ...931GS051081 The fuses are located about three inches ahead of the electrical connectors for the blower motors. The part number for the fuse is N 017 1315. This info is from a TSB from July 9, 1986. JR
Emission,
If your fuses check out Since you live in a warm climate JR
Javadog,
What year/model car do you have? I'm trying to gather up information so I can posted it
