944 Ignition Switch Wiring
Hi all!
I'm a newbie to this forum and I'm having a few electrical probs with my 944.
Does anyone know the wiring for the ignition switch on an 85 (oval dash) car?
att
I've attached a picture of the pins on the switch but I need to know which wires connect to which pins by colour?
Also, has anyone done a fuseboard swap out? Do you have any advice or did you encounter any problems it'd be useful to know about?
Much appreciated!
85 LHD 2.5 8v 944
Old 11-30-2006, 11:09 AM
Razorback1980's Avatar
Welcome to the forum. The plug should only go on one way so I don't pay attention to which color wire goes where. There are electrical diagrams on this site to help you figure out most of that. The other invaluable resource you want to check out is clarks-garage.com. There is a vast amount of good information in there. If you don't find what you need, let me know and I'll try to look it up.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 11-30-2006, 12:30 PM
Connector
Hi Razorback,
That's the problem, I stupidly removed the back of the cover with the intention of cleaning and re-crimping the contact plugs but knocked them out of the plug surround.
The Haynes manual wiring diagram isn't particularly great but I'll take a look at the two you suggested.
Thanks!
85 LHD 2.5 8v 944
Old 11-30-2006, 12:42 PM
I do this kinda stuff all the time. I call it exploratory surgery :+) Never disassembled but you should have five wires going to the Switch. Take Digi Pics in the future newbie.
P944 Ignition Switch:
30 12V Battery Red (Very Fat)
P Running Lights 12V Gray
X Switch 12V BLACK/Green
15 Key On 12V Red/Black (the Smaller)
50 Key on 12V RED/BLACK (The Bigger)
R ??
31 Ground - Brown
Old 11-30-2006, 02:50 PM
SoCal Driver's Avatar
Electrical diagrams for the early 944's are on Pelicans server. Access them from the parts page.
http://www.pelicanparts.com/944/electrical/944_electrical_diagrams.htm
The later 944's with the oval instrument cluster would use the diagram as pictured in the previous posting. There is a difference.
Old 11-30-2006, 03:59 PM
Thanks!
Thanks alot for those!
I'm going to make a start tomorrow so hopefully all will go well.
I usually do take pics but that's what you get for being complacent!
85 LHD 2.5 8v 944
Old 12-01-2006, 09:53 AM
Okay I have a 1986 base model 944 I just did the same thing what do I do to fix it? Mine has six wires
Old 07-10-2013, 02:50 AM
Read the above post!
Old 07-10-2013, 04:04 PM
Porsche Crest 1986 Porsche 944
How do i just hook the ignition up to a toggle switch without no key at all?
Old 07-21-2013, 12:29 PM
I really need help I bought a 1986 944 and it didn't come with a key I bought a new ignition switch and I can't get the old one out I need help how do I take the steering column off cant figure out the bolts
Old 07-23-2013, 04:23 AM
Proprietoristicly Refined
John_AZ's Avatar
replied:
1986 Porsche 944 ignition switch replacement help!!!
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 07-23-2013, 05:21 AM
