Slumlord
Porsche_monkey's Avatar
Nitrogen Filled Tires
Anyone using nitrogen rather than compressed air? Parker Hannafin claim less leakage, less rim corrosion and longer tire life.
Who's tried it?
Old 07-18-2003, 07:52 AM
What about helium? It's lighter than air, so it saves weight.
That and the carbon fiber e-brake handle translate to more hp.
anthony
Old 07-18-2003, 07:55 AM
Slumlord
I think the molecules are too small, would leak more than air, wouldn't it?
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 07-18-2003, 07:57 AM
Slumlord
The danger of nitrogen is...?
84 Cab - sold!
Old 07-18-2003, 08:05 AM
IROC's Avatar
Air is over 70% nitrogen anyway, so you're already using nitrogen in your tires. :>) I think controlling the amount of moisture in whatever gas fills your tires would be more important.
Helium would leak like crazy.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 07-18-2003, 08:14 AM
Information Junky
island911's Avatar
AIR is a mixture of nitrogen and O2. Air also contains water-vapor.
The water vapor can, more drastically, add to the pressure swings, due to tire temp changes.
If you're worried about rim corrosion, you're likely running steel rims. (?) . . .in which case the water and O2 can cause problems.
FWIW, at a service station, most of the water in the compressed air has condensed out, and is laying at the bottom of the tank. If you fill your tires with a pump (directly) the air you get may be extra wet. (it's a dew-point thing)
Old 07-18-2003, 08:19 AM
304065's Avatar
I think Mike has it: the moisture content is responsible for variations in tire pressure due to heat.
Another reason is that air jacks and impact wrenches for center-lock wheels all run off N2. Something like 400 PSI is used for the air jacks, why run a compressor when you can just change the regulator and fill the tires?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-18-2003, 08:20 AM
LOL, air is 78.1% Nitrogen and 20.9 % Oxygen. Tires on large transport and bomber aircraft were sometimes filled with pure Nitrogen to save weight (it adds up when one has a lot of tires), reduce fire hazard and corrosion. Agricultual tractor tires are filled with "chloride" (saturated salt solution) to increase weight. Hardly, worth it on ground vehicle tires unless it's an application where one can't easily check or refill the tire inflation gas. Jim
Old 07-18-2003, 08:23 AM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
I use Nitrogen on aircraft tires and all pneumatic systems. The biggest issue is moisture, weight savings is negligible, even at that level. The lack of moisture contributes to more stable pressures during temp swings and less corrosion & contaminates. Nitrogen is great, but I do not think it would be worth the expense and hassle to use it on your car tires.
If you have a cheap and convenient source, go for it. Be aware that the biggest hazard with nitrogen is, of course, the lack of oxygen. If you bleed off nitrogen in an enclosed area, it will displace/dilute the O2 and asphyxiation can occur, so use it in a well ventilated area.
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 07-18-2003, 08:58 AM
Slumlord
Welding cylinders, or die spring re-chargers, either one is a good source.
84 Cab - sold!
Old 07-18-2003, 09:28 AM
Didn't Porsche use nitrogen in racing tires because it was more stable than regular air in the tires as far as pressures go? Seems like I've read that somewhere.
Tad A.
82 911SC Targa, Euro
Sadly down to 1 Porsche, for now...
Old 07-18-2003, 09:29 AM
Diss Member
Quicksilver's Avatar
It used to be a common practice to use a nitrogen bottle to run impact tools in the better funded pits. It was an obvious choice to fill the tires with.
Mostly the nitrogen in the tires bit is mostly a wives tail. If you are really worried about pressure change then I would just run a decent quality line drier.
Putting a car in a nitrogen filled bubble is sometimes done to prevent any sort of deterioration on a concours car but most people just use the filtered air bubbles.
Helpful hint -> If you want to see how much rust you can form inside of an impact wrench, just try using CO2 to run it for a while.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 07-18-2003, 10:12 AM
911 user
Milu's Avatar
It's used quite a lot in Italy especially on bikes. Biggest advantage is that tyre pressures are supposed to be more stable. I think what is used is actually a mix of inert gases rather than just nitrogen.
Where once the giants walked now Mickey Mouse is king.
My other car is also a Porsche.
Old 07-18-2003, 11:14 AM
I put Nitrogen in my 930's tires. When I take my tires to have them mounted, I come home, pull the Schrader valves out and drain all of the air out,and let the tire/wheel sit for a while and then I fill it full of Nitrogen.
At the track, it makes the pressures much more stable. My pressures do not fluctuate as much from the beginning of a session to the end of a session. With normal air I was getting as much as 10-12psi increase in the tires.
With Nitrogen I see about 4-5 maybe 6 on a really hot day.
Brian Keith Smith
Old 07-18-2003, 11:49 AM
Randy Webb's Avatar
"at a service station, most of the water in the compressed air has condensed out, and is laying at the bottom of the tank."
- The air will be at the saturation point for that temperature and pressure. This means there will be considerable water vapor in the air. Whether that's a problem or not is another question entirely. Water vapor in an air parcel is different from actual water "droplets' in the air these droplets are microscopic, much smaller than a "drop" of water.)
Old 07-18-2003, 01:49 PM
Slumlord
Plus, most gas stations don't even use tanks anymore. You get your air direct from a crappy little $20 compressor.
84 Cab - sold!
Old 07-19-2003, 04:45 AM
on-ramp's Avatar
how about Hydrogen? It worked for the Hindenberg
Hydrogen is also by far the most abundant element in the universe and makes up about about 90% of the universe by weight.
Old 07-19-2003, 05:48 AM
Slumlord
Molecule size, worse than helium. It's that atomic number thingy.
84 Cab - sold!
Old 07-19-2003, 07:09 AM
Zeke's Avatar
If it doesn't freeze in your hand first.
Wives tale? I don't think so. Nitrogen is used in the pits for both the reasons listed above, it is stable and it is already there for the air tools.
I have N2 in my race car tires and in my Boxster tires. On the Boxster, this is mostly due to the tire shop's preferrence. However, the guy who does my tires is renowned for his balancing work on Bonneville LSR cars. He states a convincing case for the use of N2.
Old 07-19-2003, 07:12 AM
Banned
CO2 will form rust?
i thought that you needed oxygen for rust to form?
Old 07-19-2003, 09:45 AM
