Errr - small pool of oil in my ... airbox?
I was having a bit of quiet enjoyment tinkering with my 84 944 this afternoon. On my way to doing something else, I removed my air filter cover and filter (first time since recently purchasing the car) and looked over the inside of the airbox, looking for dirt, etc.
What I found was a small (approx 3-4 cc) of dirty oil pooled in the rear driver's side corner. The rest of the air box was clean - no oil trails from anywhere.
The car seems to run just fine.
Has anyone ever seen/heard of this before? Should I just forget about it?
84 944 5spd
Maint. & Fixes made thanks to the help received on this board:
Rear Hatch Pins, Oil Change, Dash Cover Installation, New Rear Seat, New O2 Sensor, New Ignition Switch, New Fuel Pump Relay, Rear Light Assembly Reseal, Instrument Panel Short Circuit, New Speedo Cable, New Timing belts and Starter.
Old 11-27-2002, 03:24 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Is it, perchance, a K&N filter?
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 11-27-2002, 04:32 PM
crankcase is vented to box, might have worn rings & getting some blowby. I wouldn't worry too much unless it gets to be a whole lot.
drew1
Old 11-27-2002, 07:09 PM
Is it a K&N filter?
Well, I've never purchased a K&N filter so I'm not sure what they look like. I've heard one must oil them which leads me to suspect they use foam of some sort as the primary filtering element ... My current air filter looks like it uses paper as the primary filtering element. It doesn't have any manufacturer's logo on it ...
As far as crankcase blow-by is concerned - I would think my air filter would be fouled with oil/crankcase dirt (which it doesn't seem to be).
Do 944s have PCVs or is the air box the defacto PCV?
Thanks.
84 944 5spd
Old 11-27-2002, 07:41 PM
todwic's Avatar
The crankcase vents to the air box under the filter, so no oil on filter would be there present on. K&N Filter is just like the regular filter except instead of a paper medium it uses cotton cloth. The oil is like WD-40 except its red tinted. I don't think there's a pvc valve.
'86 951
Old 11-27-2002, 08:57 PM
Smile
Oil in the airbox is not rare and the issue has been brought up here on Pelican from time to time. No one seems to know the answer as to why. I had a bunch in mine before I installed my K&N. If you don't already have one, I recommend purchasing a K&N air filter. Good luck!
Stephen
Old 11-27-2002, 11:08 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
THat's not as weird as what I found in my air box...
...you guessed it: Frank Stallone.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 11-28-2002, 08:36 AM
Old posting reference to oil in intake?
Well, after searching old postings I found one that had the following comment:
"Had the oil in airbox syndrom as described when I first purchased my 84' 944. It turned out that I had a bad brake booster and various other vacuum leaks that was pulling the oil out of the intake. Fixed the vacuum leaks and no more problems."
What does he mean by "was pulling the oil out of the intake"? I didn't know oil EVER was part of the intake?
Thanks.
84 944 5spd
Old 11-28-2002, 09:44 AM
todwic's Avatar
just guessing, but he prolly meant pullin the oil from the crankcase.
'86 951
Old 11-28-2002, 05:15 PM
Send a message via AIM to Trevor
I just found oil in the intake hose from the air filter in my 96' Jetta. I'm glad to here you guys don't think it's a big deal. Anyone want to buy a Jetta?
1987 Black/Black (sold)
96' Jetta (RIP)
1986 N/A (Sold)
2001 Taurus noooooooooooooo!
1993 325is
Old 12-01-2002, 09:38 AM
todwic's Avatar
I found how the oil was getting into the airbox when I took my oil filler tube off. On the side of the oil filler is a thingy that has a vacuum line on it. It goes to the breather eventually. It looks like a pcv valve but it's not, it's just a straight shot.
'86 951
Old 12-01-2002, 10:56 AM
