LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
efhughes3's Avatar
Optima power!
My Interstate "old school" battery gave up the ghost after 7 years-I'm surprized it lasted as long as it did. So, I went to an Optima, and wanted to show off the mounting details. As was posted by Wil Ferch, I made a base out of poly cutting board, and countersunk the holes on the bottom side. This allowed me to use flathead S/S screws to bolt the battery to this new base.
The base then fits under the stock rear mounting lip, and a new allen head bolt uses the stock bolt location toward the front. It's in quite solid. Beyond that, a new 9" HD ground strap ($4.95) from Pep Boys (where I got the battery also) finished the installation, other than a little black Rustoleum under it all.
Note, I moved the mounting holes back about 1/2" from from the tapered end from what is shown on the plan at the bottom here, originally posted by Wil.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 02-05-2007, 11:22 AM
Designer King
Paulporsche's Avatar
Nice job. How thick is that cutting board?
Paul
Never leave well enough alone
Old 02-05-2007, 12:36 PM
efhughes3's Avatar
It's about 3/8" thick...
Ed Hughes
2015 981 Cayman GTS
Old 02-05-2007, 12:40 PM
naturally aspirated
Palum6o's Avatar
This is great. I think Wil's pattern was asymetrical? (I wasn't sure why). I believe the cutting board material can be dyed by boiling it in water with just the black RIT clothing dye, I did that before with plastic and fiberglass parts before and looked great.
Old 02-05-2007, 01:32 PM
efhughes3's Avatar
The pattern doesn't look asym., but I didn't like the way the battery sit with the original hole placement. The tip about dying the plastic is interesting, I may look at that.
Ed Hughes
2015 981 Cayman GTS
Old 02-05-2007, 02:55 PM
steve911's Avatar
Looks great.
BTW, you can also buy black cutting boards - target has them - same price as white. Probably less messy than dying a white board.
Ed--
What size bolt did you use to hold down the board in the trunk?
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 02-05-2007, 03:16 PM
84CAB's Avatar
Just don't let the water with black dye boil over. The wifey will be very upset. ASK ME HOW I KNOW.
ELVIS 84 CAB -SOLD
Old 02-05-2007, 03:24 PM
efhughes3's Avatar
Originally posted by steve911
Looks great.
Ed--
It's an M8 x 1.25 X 25mm long.
Ed Hughes
2015 981 Cayman GTS
Old 02-05-2007, 03:33 PM
goat's Avatar
That looks very nice.
Almost in the same boat just waiting for the old battery to die, I have a metal plate that I cut and have yet to drill the holes to attach the battery.
Tim.
1988 911 Carrera. Silver.
1973 914 Metalic Blue.
2012 Cayenne S
Old 02-05-2007, 03:45 PM
mark '87 930's Avatar
Thanks for that... I just did mine according to your plan. The only difference with mine is that I use the stock bracket and tightened it to the lip of the 'cutting board'.
I saved 3.4 lbs between the two batteries (to be honest Iwas expecting more), I used to have that honking Interstate one.
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 03-25-2007, 02:32 PM
mkimber's Avatar
Ed--Just finished installing a ew Optima in my '87. Used a poly cutting board and your directions, along with Wil Ferch's. Your directions were perfect, and the battery is fastened pretty solid.
Thanks.
Michael
1987 3.2 Carmine Red Carrera
1995 Midnight Blue 993 C4
1957 Silver Speedster Outlaw (replica)
Old 04-15-2007, 03:40 PM
efhughes3's Avatar
Glad to hear the process worked Michael! I've had my car out to the track since with no problems related to battery mounting.
Ed Hughes
2015 981 Cayman GTS
Old 04-15-2007, 04:10 PM
mkimber's Avatar
I'm glad you mentioned that you had your car out to the track without any problems. I was wondering whether the battery mounting would pass the inspection when I go out for the first DE this year.
Michael
Old 04-15-2007, 05:06 PM
efhughes3's Avatar
Ahh, well having no problems and passing inspection are two different issues.
I guess it may depend on the inspector and their SUBJECTIVE judgement on the setup. In my opinion, it is more secure than a standard battery as the battery is bolted to the board, and the board is bolted to the car. The stock battery mount requires the bracket to press down on the lip of the battery, which someone could screw up if they wanted to or didn't pay attention. To me, our new mounts are fail-safe.
Ed Hughes
2015 981 Cayman GTS
Old 04-15-2007, 05:19 PM
vmb vmb is offline
vmb's Avatar
which poly board?
I got my optima 75/35 a couple days ago and went to WalMart for the cutting board and found two boards that were big enough for the template. One was 11x14 x 5/16" thick and the other extra-large one (I believe 15x18") was 7/16" thick.
which one are you guys using? Thanks!
Vic
'79 930
'97 Miata M edition
missing my Tony//Kart 125cc shifterkart
Old 04-21-2007, 06:00 PM
Information Junky
island911's Avatar
Wow. great thread-post'n, Ed.
Old 04-21-2007, 07:01 PM
efhughes3's Avatar
Re: which poly board?
Go with the 5/16".
Ed Hughes
2015 981 Cayman GTS
Old 04-21-2007, 07:12 PM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
I like how the positive terminal is not so close to the inside of the fender also. That's always been a PIA on the stock setup.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 04-22-2007, 07:02 AM
lateapex911's Avatar
I think a tech inspector will balk at eh positive post and the lack of insulation. I'd get a red cover for it...they are available in lots of places. I KNOW I'd fail tech in SCCA with that, other clubs are different, of course.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 04-22-2007, 09:05 AM
I thought the 34R was a better fit? I haven't done this yet but someone here did. I seem to recall that you don't even have to change the ground strap.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 04-22-2007, 05:52 PM
