what is this,, it gets very hot
This loos like some type of ballast resistor that sits in with the DME and KlR.
I have noticed that it gets very hot. Too much for my taste is this normal??
What is it's purpose?
thanks
Sid
splitting my obsessions with a crow bar.
87 DD Black 951 Holset HX40-35 custom garrett turbine, Ford MAF, Rogue tuned,SLM stroker, best ET 11.4..best mph 127
Old 08-03-2007, 07:34 AM
Ornery Bastard
Is that photo of the DME mounting board? If so, then whatever that is, it's a hack-job by a previous owner.
Old 08-03-2007, 08:38 AM
Yea actually they aren't mounted at all. I will make a nice alum mounting brace for them.
Do you know what this is?
Sid
Old 08-03-2007, 09:24 AM
cold starter
JustinL's Avatar
Without knowing exactly what wires are in there, I would guess that the PO of your car upped the size of the injectors and used low impedance ones. Without those resistors, the injector drivers see all that heat and then burn out the DME.
Again just guessing because I use ballast resistors with my 55lb injectors.
88 Turbo S Silver rose: Megasquirted fuel, assorted suspension upgrades, etc.
89 944 S2 with 968 engine: Race car
87 944: Chump car build in progress
Old 08-03-2007, 10:23 AM
That was my initial thought but these are much larger wires than the injector wires.
I'll try to get a better photo of it.
Sid
Old 08-03-2007, 10:32 AM
Also I ran the bosch # and they are the porsche 42 # injectors so I kinda ruled that out right away.
I had done an OHM reading on the injectors and they are about 5. not the 2.4 of the std low impedance style
Sid
Old 08-03-2007, 10:33 AM
soxnail's Avatar
Ohm the ends on them to the Injectors and see if they lead there.
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 08-03-2007, 05:30 PM
I'll try that, but it really doesn't look like these go to the injectors or anything related to the dme.
They were initially up above the dme and KLR.
Is there something else that requires this type of resistor. Heater,, alarm??
Sid
Old 08-04-2007, 12:17 AM
soxnail's Avatar
Well there are resistors for the speed of the vent fan iirc..
Sox
Old 08-04-2007, 08:15 AM
winter-hater club member
nynor's Avatar
Sox
its a plug that live between the firewalls near the blower.
"COOL PRIUS!" - Nobody Ever
Old 08-04-2007, 09:16 AM
Keithr726's Avatar
Send a message via AIM to Keithr726
I have these in my car too, I too am curious to their purpose.
Keith
1986 Porsche 951
Old 08-16-2007, 10:59 PM
911 Abuser
Ionizer's Avatar
Ballast resistors for a high power ignition coil?
Old 08-18-2007, 12:31 AM
Got Turbo?
PAUERMAN's Avatar
These are the resistors for the blower motor. They control the speed(s) of your fan.
Vic Timpauer - www.pauertuning.com Mesa, AZ
944 Turbo S - Plug & Play Vi-PEC V44 EMS, GT3076R
DynaPack Dyno:
358whp/352lbft @ 18.5 psi 91 pump
438whp/430lbft @ 22.5 psi E85
Old 08-18-2007, 09:06 AM
Aren't those the resistors for the radiator cooling fans? I know on the earlier cars they were mounted under the dash, on the late they are mounted next to the battery. I have an '88, they are located by the battery, and look just like that.
The blower motor for the heater/ac has it's own resistor inside the blower motor cover. It's long and skinny and a lot smaller than the ones pictured.
Again, my info is based on the way my '88 is set up so I can't be 100% sure about yours. Here are the radiator cooling fans resistors on my car:
-- Jim
1983 944
Old 08-19-2007, 12:37 PM
Thats them thanks.
PO must have routed them inside?
Sid
Old 08-20-2007, 07:19 AM
Keithr726's Avatar
The wires on mine were seriously crumbling away so I replaced a few inches of them along with all new connectors. However I broke one of the small plastic things next to one of the resistors. What is it? Can I run without it like the late style car above?
The late car in this picture has them. I'm confused.
Wiring Question
Heres mine
Keith
1986 Porsche 951
Old 04-28-2008, 10:21 PM
cb951's Avatar
They're cooling fan resistors. Best bet is to find some used. Try 944 ecology or parts heaven.
-Chris
'86 951 (daily driver with occasional DE)
Mods: A few.
Old 04-30-2008, 06:33 PM
soxnail's Avatar
As far as I can tell on the 86' year there are two 0.92 ohm bulk resistors. I do not see the extra piece. This may be a owner "special" ??
Sox
Old 04-30-2008, 08:23 PM
