Engine Shroud Painting, Help!
Hello everyone,
Question: My shroud for my 3.2 Carrera was painted and I was wondering what the best and safest way to remove the paint. Aircraft paint remover or what? I'm looking for methods other than sanding the paint off. 2nd Question: I'd like to pain it RED so what is durable and recommended and where can I buy some?
Thanks,
Alex
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 05-01-2007, 11:13 PM
1962 356 Ruby Red
it's a blood red
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-02-2007, 12:06 AM
Re: Engine Shroud Painting, Help!
It's acrylic urethane. It's expensive.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-02-2007, 12:08 AM
dweymer's Avatar
very nice Ronin.
You have to sand some to rough up the surface for the new paint to stick. If yours is sound, there is no need to remove all the paint.
Degrease the whole piece VERY well, then sand with 120. All paints will have different prep instructions, so make sure you get them. You can get pretty good auto paint premixed in a can from paintscratch.com or other places.
Donnie
Currently Porsche-less.....
Old 05-02-2007, 12:16 AM
Less brakes, more gas!
euro911sc's Avatar
I stripped my Shroud and fixed all the broken bits:
This:
went to this:
There was no stripping of paint that could be done. I had to sand it all down after I drilled out the rivets on the metal guide. I used West systems to patch all the holes and breaks. I'll re-drill the holes during reassembly of the motor. Looks very nice.
I used recommended Krylon Fusion over primer:
Painting Engine Shroud
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 05-02-2007, 06:16 AM
Targa, Panamera Turbo
M.D. Holloway's Avatar
Mines green - I want to do the same thing but paint it the original green. Good info!
Michael D. Holloway
https://5thorderindustry.com/
Old 05-02-2007, 06:23 AM
Nice work everyone and thanks for the recommendations and pictures. It's next on my project lists.
Best Regards,
Alex
Old 05-02-2007, 06:28 AM
euro911sc's Avatar
I think it is near impossible to achieve the original look. The early shrouds had the color impregnated into the resins and the nice OEM FG texture cannot be duplicated with paint
Also, at least with mine, the surface was incredibly porous with lots of little voids that the paint had gotten into so if someone painted it a different color then the OEM color it would be tough to extract all of the paint out of the voids leaving a less then acceptable result.
Getting back to OEM IMHO is not possible after all this time unless you can do it with soap and water. That said, I love the results of my work and only a concours nut would complain and that, I am not... yet
Best regards,
Michael
Michael
'13 Cayenne GTS
Old 05-02-2007, 06:43 AM
