haycait911's Avatar
well, rod knock no longer a mystery.
finally got my rod knocking 3.0 torn down. ALL of the oil passages to the big rod bearings were blocked to one degree or another. two of them blocked completely at both ends! there is a kind of reddish plastic stuff stuck at the ends of the passages, against the bearings.
not sure what it is, kind of a hard plastic. the case was FULL of black silicone-like chunks. I'm thinking from a fairly recent rebuild, extra sealant squeeze-out. crank journals look fine so I'm hoping to get away with new bearings only, but will get crank miked.
moral of the story, when assembling, CLEANLINESS IS KEY!!
this ends our public service announcement, thank you.
P.S. to Wayne. your book is a lifesaver. thanks!
Old 10-14-2007, 12:33 AM
haycait911's Avatar
tough to get a decent pic of the gook out of the crank. it's translucent orange and I can cut it with a fingernail. here's a couple of more pics showing the degree of cr-p in the case. this isn't oil sludge, it's like silicone or maybe permatex 2.
Old 10-14-2007, 01:56 AM
DUK DUK is offline
DUK's Avatar
I hate to ask but what oil was being used. I know you won't believe this but I saw almost the same thing when a 5.8l Ford was broken in and ran with Sohio oil (now BP). It clogged his hyd. lifters and made them tick loudly so it never got this far.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 10-14-2007, 06:10 AM
gestalt1's Avatar
it looks like on the case mating surfaces there is black silicon squeeze out still on the edges. i don't see why there would be loctite 574 in an engine that has so much black silicone used. maybe the orange stuff is some other type of silicone sealent, isn't silicone's natural color orange? any idea who rebuilt this engine?
Old 10-14-2007, 08:03 AM
sure looks like 574. the orange suff that is.
206 637 4071
Old 10-14-2007, 08:13 AM
Diss Member
Quicksilver's Avatar
My first impression was that it was plastigauge but there is too much goo there.
I can't see that this motor could have run very long this way. It shouldn't be hard to chase down the culprit.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 10-14-2007, 11:38 AM
haycait911's Avatar
the only journal that shows any damage is the one closest to the flywheel, surface is a little dark. that one had a completely plugged passage and a slightly scored bearing. I can't even get a wire thru it to clear it. I think you're right quicksilver, it couldn't have been run long like this. I ran the engine maybe 5 minutes when I got it, before pulling it out. it appears silicone WAS used to seal the case halves, so who knows what the red gook was used for. I'll get the crank checked and maybe polished and new rod bearings. count myself very lucky and move on.
Old 10-14-2007, 01:49 PM
was 574 used on the mainwebs?
206 637 4071
Old 10-14-2007, 02:29 PM
