problems arising with metal steering bushing
the steering shafts are starting to wear out because those replacement steel bushings for the top bearing are rubbing on them metal to metal. considerable wear, enough sometimes to make you think the car needs that bushing repair, when it already has one installed. so if you have one, i would recommend removing it for inspection and/or lube it real well with a long lasting grease like optimoly, and maybe check it yearly. the shaft replacement is very time consuming and expensive. just don't install them dry.
206 637 4071
Old 10-16-2007, 04:41 PM
sudo apt-get purge 930
equality72521's Avatar
Thanks John.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL***
"Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing"
--clutch-monkey
Old 10-16-2007, 04:55 PM
Ferdinand Magazine
johndglynn's Avatar
I lubed mine on install back in May, but will check it again over the winter.
Thanks John.
Sheriff at www.impactbumpers.com
Brand support at classicretrofit.com/tuthillporsche.com
1976 Porsche 911 Carrera 3.0: 'The Orange' - 1981 924 Turbo - 1983 944 Lux - Too many BMW motorcycles
Old 10-16-2007, 05:01 PM
burgermeister's Avatar
Is this the steering shaft that attaches to the steering wheel (and the bearing is the upper steering column bearing), or is this the steering shaft that attaches to the rack?
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 10-16-2007, 05:07 PM
Norm Faustino's Avatar
A very good technical bulletin indeed.
Thanks John, I did install mine dry but I haven't driven the car yet, due to the restoration down time. I will make sure to glop a bunch of moly in there for sure.
78 911 SC "Scratchy"
2004 Mini Cooper S "Pele" (gone but not forgotten)
1979 classic mini clubman-"Coolio"
Any recommendations on process/tools for removing these? I had to pound the hell out of it to get it seated completely.
Old 10-16-2007, 05:58 PM
yes, the upper shaft just below the steering wheel. i've put lots of them in dry. guess i won't any more. my accountant's shaft was very badly worn, and i just found another today. just a friendly warning.
206 637 4071
Old 10-16-2007, 06:10 PM
Cooper911SC's Avatar
Thanks ALOT for the nice heads' up John! I lube mine soon!
Cooper
Cooper's Classy Car Care
Providing Clear Bra installation, Paint touch-up, Detailing
PCA/OCR since 1997
'81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter
Old 10-16-2007, 06:14 PM
usually they slip right in with virtually no effort. i guess you'll have to get creative, or just keep a lookout for any extra play happening. then it should come out nicely. you would think it would turn with the bearing, but apparently not always.
206 637 4071
Old 10-16-2007, 06:15 PM
Thanks for the heads up!
Old 10-17-2007, 10:25 AM
Friend of Warren
Another thanks JW!
Kurt V
Old 10-17-2007, 11:02 AM
kbruz's Avatar
Over the last several weeks my steering wheel has started to wobble. I read numerous threads about how to do this. I have a couple of questions.
How does one remove the old plastic bushing so that the metal one can be installed?
No one seems to change the bearing out. Is this difficult to do? Do you have to remove the steering column?
kb
mercedes GLK350
2009 boxster s
86 targa
Old 11-03-2007, 09:58 PM
Tsunamiboy's Avatar
Subscribe
Tsunamiboy
1979 911 SC (3.2L)
1997 Boxster 986
Old 11-03-2007, 10:14 PM
HarryD's Avatar
Check the tech articles (http://www.pelicanparts.com/911/911tech_articles.htm) for what you need. For the bushing, try this one: http://www.pelicanparts.com/techarticles/911_Steering-bushing/911_steering_bushing.htm
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-04-2007, 12:02 AM
rnln's Avatar
John,
thanks for the warning. I bought the bushnig maybe a year ago but never install it yet, since there always something more important to do. Plan to do it this or next weekends. Guess I will hold this task off, again.
I think if they can be worn by rubbing, then lubing/greasing might not be a long term option. Please post if you come up with better solutuion(s).
Again, thank you.
Fat butt 911, 1987
Old 11-04-2007, 01:59 AM
p911dad's Avatar
Thanks John for the heads-up. I installed a sleeve a few years ago, and I noticed recently a little lateral movement in the shaft while driving. I will pull it today and check. Glenn
Old 11-04-2007, 03:49 AM
COL 911
COL 911's Avatar
Replaced my plastic bushing with the metal sleeve last October, no probs until I read these recent posts about applying grease. Concerned me abit, so I went back into it...
Today removed steering wheel, etc., metal bushing lifted right off with gentlepressure on the lip w/ screwdriver. No signs of wear on the metal sleeve. Some signs of 'light oil' on the sleeve, but I reinstalled it after coating inside and out with heavier grease.
May be perception over fact, but after the lube, the wheel seemed to turn smoother and with less effort.
Old 11-04-2007, 02:25 PM
khamul02's Avatar
One more mini project. Thanks John, seriously.
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 11-04-2007, 06:01 PM
chrisp's Avatar
John, how many miles are you talking about here?
'83 SC
Old 11-04-2007, 06:16 PM
hard to say. some will never wear because they turn on the bearing, not on the shaft. others will allow the shaft to turn inside them, and that's where the problem is.
206 637 4071
Old 11-04-2007, 06:47 PM
