Fresh 3.2 Short stroke for sale
3.2 SS short block
10.5 JE pistons set-up for twin plug LN Engineering cylinders Arp rod bolts factory steel head studs (24) New alternator New hardware kit oil return tubes..etc., etc.. The impending change in my marital status( divorce) forces the sale of most of my Porsche toys..This sucks in a major way... The engine is complete unassembled ..except for the short block.. No intake or exhaust.. I will personally deliver within a 300 mile radius of louisville Ky $5500.00.OBO.Dan ![]() ![]() ![]() ![]() ![]() ![]()
I have plenty of lead for my pencil... just not enough paper to write on.. 82SC with 95 993 engine 2004 Ford Powerstroke |
That will be a badass motor, one that should put lead in any pencil. What do ya think HP numbers will be with the correct fuel/exhaust options?
To me sounds like a quick setup, one needing the correct application, but probably badass if used corectly. What a killer.
I'll be your huckleberry (my great uncle was Doc Holiday) |
up-fixing der car(ma)
Does it have any heads or cams?
Thanks, Scott
Scott Kinder kindersport @ gmail.com |
Scott..it's a complete engine.. the heads and cams are the stock 3.0 ..
Wih proper heads .cams and intake.. 290hp would be easy.. i would think..
ouch!
Somewhere in the Midwest
Crap! I'm so sorry to hear about your situ, Dan.
Guys, Dan is a great guy, and I know he took great care and did his research to get to this point. This is an excellent deal. I wish I could free up the cash to buy this from you. Dan. Maybe I'll find a way if someone doesn't run away with it. |
I sent you an e-mail Dan.
Work in Progress
Re: Fresh 3.2 Short stroke for sale
I am not a potential buyer, so if you want me to delete this I will. But I don't get it and it might help if you sell your engine if cleared up what exactly you have. Right now I am not sure if you have the long block assembled and the materials for the rest sitting to the side. Or if you are selling a long block only without intake and exhaust. I am really sorry to see someone having to let go of a dream engine like this one. I am sure you have more than $5500 into it, particularly if you include all the work you have done. Best of luck. Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
Hey Rich..I thought that my description was a bit sketchy...The engine is assembled to the point of having the pistons& cylinders installed... The remainder of the parts ...cam towers,heads,sheet metal..etc., etc... are to be included in the sale..but aren't on the engine..Hope this helps..Souk.. thanks for the kind words..Dan
Formerly bb80sc
So, the heads need to be worked to add the second plug? Are these the large or small port heads? Did you do research on what the best cam would be, or how aggressive you could go?
Sorry to hear about the divorce. I hope you get to keep the SC with the 3.6 motor ![]() ![]()
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
You have a PM
Brad.. My original intent was to sell these heads(3.0) and buy a set of 3.2 heads with the proper port size..and add for the 2nd plug..I had Talked to Henry Schmidt about building the heads..He said it would be cheaper to use the3.2 s.. rather than hog the 3.0s..Hadn't gotten to the cams ...was going to use Camgrinder(John Dougherty)Brad thanks for the kind words..About the SC it will probably have to go in order to keep my house...Dan
QUOTE]Originally posted by bb80sc So, the heads need to be worked to add the second plug? Are these the large or small port heads? Did you do research on what the best cam would be, or how aggressive you could go? Sorry to hear about the divorce. I hope you get to keep the SC with the 3.6 motor ![]() ![]()
pm sent
ELVIS 84 CAB -SOLD |
More Pics
More recent photos..
I am in the middle of a rebuild, and the attention to cleanliness is an obvious indication of the care that has been taken to this point to get this engine together.
Best of luck with your personal situation.
Than My Track Schedule 1984 911 Viper Green Track Car - Parted out to fund 1993 BMW 325is Spec E36 Race Car |
Hey Dan,
Why didn't you boat tail the mains? It's easy and adds good HP. It's Cheepest bang for the buck you can do. ![]() ![]() ![]()
Thanks! Don Ramsay E Mail: aircooledclassicsporsche@gmail.com The father of 964 Backdating! ![]() www.aircooledclassics.co www.facebook.com/AirCooledClassicsPorsche/ www.instagram.com/aircooledclassicsporsche/ |
If I had boat tailed the mains my divorce may have happened a year or so earlier..may not have been a bad thing..Dan
Licensed User
Free bump for a screaming good deal
Hey Don,
Not to dispute you, but I've been told by a VERY reputable engine builder that boat tailing the cases really doesn't add any measurable HP? Same applies to mooning the cylinders I am currently building a race motor and was going to do it but after speaking with him, was not going to spend the time? I am just trying to understand what works and what doesn't Thanks Jeff |
