Now in 993 land ...
aigel's Avatar
Thumbs up 81 SC Coupe - Street or Track - Great Value!
SOLD!!! Thank you!
Car in Bay Area. Will add current pictures ASAP. Pictures shown are some taken over the last 3 years to give you an impression. Car will be at PCA GGR AX school 07/22-23. PM for more info.
1981 911 SC
VIN: WPOAAxxxxxxxxxxxx
Clean car fax
Street car set up for track and AX events, many extra parts included
Current tech for Golden Gate PCA time trial / drivers ed.
All the common upgrades and just over 2500 pounds light!
164k miles
Sunroof Coupe
Wine Red Metallic
Power windows
radio / in dash CD
Black interior
US car with sole NV / CA history
Extensive records back to 85 supporting mileage
Mechanically very good condition
Just passed CA smog - flying colors
Just paid registration - good until July 07
Exterior is fair. Many small paint chips on front, some paint work to driver's side (Previous owner had a door dent repaired - I have the receipt) and original paint getting thin on roof. At least the roof will need paint earlier or later.
Interior is nice, with all safety updates and a new dash.
I have all records back to 1985. Also have the window sticker. I am a very active Pelican and PCA member and have owned this SC for over 3 years and have spent significant time and money getting it into top mechanical shape and make it a well performing street and track car.
I have attended autocrosses and a few track events with it. I am still a novice driver and the car outperforms me at any rate. (But even I was able to run 2:16 times at Thunderhill, there are a few seconds in there with the right driver!) The car is definitely competitive and still set up mildly enough to be driven on the street every day, including to PCA events. It is very reliable. My wife does not hesitate to drive it to the night shift when I have her car to haul things. We used it as a third car. Unfortunately we could not resist and are getting a 993, so this one has to go.
Things that need servicing: Sunroof cable is derailed or broken. (Sunroof motor and switch work). Windshield washer not working. Automatic Antenna stuck "up". Small crack in windshield (pass. side). One H4 headlight lens chipped. Tow hooks bent. I will start working on some of these smaller issues and update the listing as needed.
Engine:
Original 3.0, heads never were off, no noticeable oil consumption between changes, no smoke, no leaks.
Oil fed chain tensioners with crash safe modification (Jerry Woods' method)
Pop off valve
964 cams (by Dougherty Racing Cams) with brand new rockers
RSR rocker shaft seals
New 02 sensor
Stock exhaust (mounted)
SSI exhaust with stainless Dansk sport (dual in / single 80 mm out) included
Backdated oil lines (for SSI installation) included
Backdated heat (eliminating fan)
Factory Carrera oil cooler upgrade (replacing trombone)
Complete engine reseal in 2004
Stock ignition wires 2002
Full tune up, including valve adjust, plugs, cap, rotor, air filter, oil and filter spring 2006
Head studs checked spring 2006 - all good.
Driveline / Transmission
Stock 915 Rebuilt at approx 100k miles by previous owner. All new synchros.
Factory limited slip differential!
Shifts nicely, only up shift to 2nd sometimes takes time. Downshifts, even into 1st are smooth.
New shifter bushings throughout
New factory short shifter
New axles and clutch at 124k miles
New light weight / high torque starter
New "sport" transmission and engine mounts
Swepco fluid
Suspension
Lowered, corner balance and aggressive competition alignment by Roger Kraus Racing. Car weighs 2570 pounds with 1/2 tank of gas.
Front:
Bilstein HD strut inserts
Elephant racing poly bronze bushings
21 mm (effective) hollow torsion bars
Stock SC sway bar installed, Carrera bar (1986) upgrade included
Rennline aluminum strut brace
Weltmeister bump steer kit / rack spacers
New ball joints
Rear:
Bilstein Sport shocks
Neatrix poly bushings
27 mm (effective) hollow torsion bars
Steering:
Turbo tie rods, boots and spacers.
Brakes:
New master cylinder by previous owner
DOT steel braided hoses
ATE blue fluid
New rotors front
New pads front
Front dust shields removed
Rebuilt calipers front
New hardware front
New pads and new hardware for rear are included
Interior and Safety:
New factory dash pad!
Momo Corse suede wheel with Porsche crest horn button
New steering bushing
Autopower lipstick sized mini shift light, mounted on steering column. Set at 6000 rpm. Can be set to any rpm with included "beans".
Sparco Torino sport seats with anti sub belt hole, showing some wear
Safety Devices roll bar
Brand new Crow Enterprizes 6 point restraint system (dated 2006)
Rear seat backs and console removed for weight savings, (I had planned RS carpet.)
Fire extinguisher mount and 5 pound powder extinguisher.
Replaced sun visors and driver's side shoulder belt with good used from dismantler.
Body:
H4 headlights with matching rings
New windshield and front window seal
New rear window seal
New paint on decklid, SC badge delete
New hood badge
New hood and decklid shocks in 2003
New gas cap
Miscellaneous by previous owner:
CD box 2002
New alternator 2001
New Interstate battery 2002
Extras:
Factory 6 and 7 x 16 Fuchs for the street with brand new tires. The wheels are very nice with only one wheel having minor scuffs.
Set of factory 7 and 8 by 15 inch Fuchs wheels included (track wheels). No centercaps.
Set of 4 aftermarket 7 by 15 inch Fuchs wheels included (autocross wheels). With centercaps!
Set of 4 kumho tires (225 victoracers) with a few events left included
Engine Reseal:
Interior. Harnesses are black now. Console removed but included.
Thunderhill:
Laguna:
81 SC (sold)
Old 07-11-2006, 12:58 AM
Now in 993 land ...
aigel's Avatar
SOLD today! Thanks!
George
81 SC (sold)
Old 07-16-2006, 03:41 PM
