...is my Daughter
Avery's Avatar
Heater fan won't shut off
My friend's C4 heater fan (in the engine compartment) won't shut off after the engine is shut off. Of course, this is killing the battery. Any ideas on root cause and fix? TIA
Keep Going!
Felmir Singson RGruppe #479
"Living the rest of my life, one minute at a time"
Old 04-06-2007, 11:10 PM
Send a message via Yahoo to FRED/LI
Sensor(s) in the heat tube. Probably the probe shaped one at the top. It thinks the engine is still hot and needs cooling after shutoff.
Fred '95 Carrera2. Previous: '69S, '79SC, '84Carrera, '90 C2, 20+ years and counting......
Old 04-07-2007, 09:16 AM
P-Zero Burner
911Urge's Avatar
Sounds like a failing relay. Check the relays in the box in the engine compartment on the left side.
Stephen
2006 997 Carrera S - Sport Chrono, Full Leather
1968 912 - Purchased from Vasek Polak in 1971 and still in the family
1989 Carrera 4 - Andial service history, Sold and missing it
Old 04-08-2007, 12:05 AM
rohanveal's Avatar
just wondering if you fixed this problem as my 1989 C4 is doing the same, but the relay is working fine, therefore i assume it is the temperature sensor.
please confirm.
Old 08-23-2009, 02:25 AM
