1983 911 Euro SC, Fresh. $17,500
1983 Porsche Euro SC for Sale.
Non AC, Shows 103K ODO Gear broken. EST 150K on Body.
No stories.
No crash Damage, Rt. door repaint at some time.
Some touch up in places
2 rust bubbles below rear window. Engine lid has some cracking. Inside passenger door near striker has bubble.
Great from 10 feet. Everything works. Inc Sunroof.
Usual Rock chips,Windshield star, No Dents. Car is Pacific Blue.
Engine and all Parts listed have 10 D.E’s(Never Raced) on them and about 3K of street driving. I welcome Inspections and PPI’s Great solid car for PCA racing (Needs Seatback brace and Killswitch)or D.E’s. Selling for Lack of use. Not motivated, no overseas shipping, or lowballs please. I have over 15K in engine and supension alone.
Total engine Rebuild approx. 5K ago.
Case, Oil pump checked, and inspected by EBS. ARP rod and Head bolts. All new lower end bearings. Rods resized and balanced, Head work by Ottos. New valves, springs and Ti retainers, JE Euro 9.8/1 Pistons. All Tins powdercoated, Genuine SSI Headers, MSD Ignition, cams reground, New rebuilt rockers from EBS, Engine completely Built and Installed By Air Power Racing (Best in the Intermountain West)
Paragon Plastic bushings all 4 corners, Rear Mono-balls on Banana arms, all 4 calipers rebuilt, New fuel pump, 5 K on rotors, 2 D.E’s on Pagid oranges, Custom Rear Sway bar with 4 way Adjustable and Urathane Bushings, Crossbalanced for 200lbs, 6’3 and fit O.K. with helmet.
Trans Wevo Shifter, Syncros Replaced (per P.O, No documents), New Cv’s, 10K on Sach’s clutch. Rt. rear wheelbearing 500 miles. New Bilstiens on all 4 corners, New torsion bars 22,31mm(sway away)
New Battery, New Alternator,
Interior Full RS Carpet kit (rear seat delete) 2 Sparco Corsa Seats, Sparco belts, Momo Wheel, Cro-moly rollbar, Welded feet, Radio Delete with cover plate,
2 sets of genuine Fuchs 6 and 7’s/ 7 and 8’s - 7 and 8’s(8's from wheel enhancement) have 3 event Hoosiers on them. 6 and 7's are tired Kuhmos.
Matt
801-205-0865
matthappe at comcast dot net
Old 08-15-2007, 04:39 PM
Adds.
Cage 1.650x.095 Cro-moly was Powder coated before install( looks fantastic), Carrera oil Cooler with remoter switch, car runs cool.Monty 2 into 1 exhaust stainless, SS brake lines, New plug wires, Fuel filter,plugs,cap,rotor, Heater block off plates both sides, Most Stock Parts are included with sale, Seats interior, etc. Drive anywhere. I will gladly drive car to Miller for Inspection.
Old 08-16-2007, 07:30 AM
Rennline Alloy Floorboards both sides
Rennline
Old 08-21-2007, 08:06 AM
Cryo
All rotating parts, Inc block and heads Cryo treated.
Old 08-23-2007, 08:21 AM
New hood and deck Struts
Wow, the hood stays up without a prop rod.
Old 08-26-2007, 09:45 AM
Hydro Tensioners and Pop-off
Of course...New Chains Also.
Old 08-28-2007, 12:13 PM
$15,500 without 7 and 8's
I'll accept $2000 less without the 7 and 8's and the rubber.
8's are Almost perfect. Hoosiers are 8 heat cycles.
Old 09-12-2007, 01:04 PM
New Photo
Replaced oil bypass crush washer car has not dripped a single drop in 7 days.
Old 10-07-2007, 10:53 AM
Recent fuel pump
New Fuel pump within 3000 miles
Old 10-11-2007, 11:36 AM
Listed Now at $16.6 Firm.
bump
Old 10-23-2007, 12:39 PM
bump
bump
Old 10-31-2007, 10:48 AM
Still taking up Garage space..
Old 11-20-2007, 06:19 PM
$16.5 with 7/8's
Old 12-05-2007, 03:05 PM
Spring is Near
Bump
Old 02-16-2008, 05:00 PM
Sunshine is here..
$16.5 with 7/8 Fuchs and Hoosiers..
Matt
801-205-0865
Salt Lake
Old 03-04-2008, 07:50 AM
16K with 7/8's and Hoosiers
Bump
Old 04-01-2008, 08:22 AM
Bump
bump
Old 04-15-2008, 01:53 PM
bump
Still for Sale.
Old 05-01-2008, 08:04 AM
