Architecture & Porsche's
'81 928 5-speed track-car for sale: $6900
Selling our beloved Penny due to GT2-spec 928 racecar build-up (another project). Rescued from a Pawn Shop in 2006, she has gone through the wringer getting up to par & reliable. Asking price is $6900, below is our list of maintenance & modifications.
All work performed by 14-year PCA member & co-member with experience building/rebuilding/restoring 928’s with extensive 928 maintenance experience: engine rebuilding, clutches, suspension work etc, utilizing factory 928 manuals & torque-specs.
Engine:
Completely re-sealed engine in 04/07 including:
-bare long-block re-seal:
-reseal heads (headgaskets, OEM)
-cleaned, painted, intake manifolds with new gaskets
-cleaned & re-hosed (Goodyear EFI hose with EFI hose clamps) fuel injectors
-Rebuilt front fuel hoses (Goodyear EFI w/EFI clamps) off hard lines in engine
-all new zinc-coated engine bolts including anti-seize
-most all breather hoses are new, including brake booster.
-front & rear main seals
-New T-belt, Rebuilt tensioner, rebuilt water pump, new idler & tensioner rollers
-Re-seal oil pump with new bolts
-New 73c low-temp thermostat & seal
-New Battery in 02/08
Hydraulics:
-Master Cylinder has been replaced before (left alone), new soft-hose feed line.
-New OEM clutch-master cylinder & new hard line from master cylinder
-New OEM clutch slave cylinder & hard line
-Correct Early 928 Proportioning valve for better braking
Clutch:
-Tested used pressure plate, good clamping force
-Clutch discs: both are OEM new, perfect shape
-Cleaned & tested intermediate plate
-Cleaned & smoothed OEM flywheel
-New Pilot bearing
-New Throw-out bearing (release bearing)
-New/Used guide tube
-New flywheel bolts (Grade 10.8)
-New release arm bushing
-New Soft fluid clutch hose
Brakes:
Front Brakes: ’87 928S4 spindles with re-packed bearings using Amsoil grease
-Factory Porsche OEM Front S4 rotors with painted hats
-Factory 928S4 Front Calipers (painted Red via G2 kit), new OEM Caliper Bolts
-PBR Street/Track pads (no squeal)
Rear Brakes: New OEM rear rotors with painted hats.
Suspension:
-Sport springs front, stock shocks with added threaded spring perches ft/rear
-928S4 front sway bar with Energy suspension bushings.
Steering:
-OEM Rack, no leaks.
-New Tie rods & boots, both ends
-Redline Power Steering fluid & re-sealed low-pressure line
Cooling:
-Phosphate-free coolant added with 1pt Water-wetter after full cleanse & flush.
-New coolant hoses added where needed
-New low-temp 73c thermostat & o-ring
-Mechanical fan delete due to air pump idler
-High-performance 16” pull-fan installed at backside of radiator.
Exhaust:
-OEM Cast manifolds (new gaskets), & y-pipe, new Bosch O2 sensor
-Fresh aluminized-steel 2.5” straight exhaust with single stainless 2.5” dual
Tip muffler hung at rear. Incredible song!!
Electrical:
-All normal electronics needed to power vehicle & pass inspection are fine.
Fluids:
-Brad Penn Racing oil: 20w50
-Redline Transaxle fluids: 4 quarts Shockproof, 2 quarts MTL
-ATE Super blue Brake fluid
Transaxle:
-Stock ’81 transaxle & torque tube: So/so syncro’s for 1st, reverse. 2nd & 3rd are easy enough to find & 4th & 5th are perfect. Transaxle has 2.75 rear end (short gears for a 928), so for most courses and with the V8, 4th & 5th are most commonly used.
Shift linkage was rebuilt: new front pivot bushing on front of shaft, center support for front shaft has been reinforced, new shifter springs & bushings, a new rear shaft was substituted for worn rear shaft, & rear u-joint was rebuilt with new bushings.
Wheels & Tires: Car comes with Factory Dish wheels with so/so Yokohama tires for listed price. 18” 993 Cup wheels with new SO2’s in the rear (265/35-18) + so/so 225/40-18 SO3’s in the front are available for $1000 more. ROH Modena’s pictured not for sale.
Penny was copper (yes), but now has a fresh flat-black & semi-gloss-black racing paint job: good enough for track, good enough to get the car around, not good enough for showing. 
Interior is stripped of all interior dressing with the exception of the headliner & sunroof panel for thermal protection. Only the instrument pod, shifter, & pair of blue/black Corbeau racing seats remain. There is no AC/heating, console, dash, quarters, rear seats, door panels, or carpeting in Penny as she was destined for the track. Great glass, flawless windshield.
Porsche Club Racing National Scrutineer
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 02-19-2008, 08:37 AM
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 02-19-2008, 01:18 PM
Mark, you have a pm
Reddog928
Old 02-19-2008, 07:14 PM
Penny
Thanks Reddog, I'll check it.
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 02-20-2008, 05:42 AM
