7.0:1 > 11.3:1 > 7.0:1
BBS wheel centers
****Sold***
I have 10 of these BBS motorsports wheel centers for sale. 20 bolt. P-car 5 on 130 bolt pattern.
They are all 10mm offset from the flange to the surface where the halves mount.
6 part number 0250277 model E50
4 very similar to above part number.
$500 per pair.
One pair is $300.
All are good, no cracks, but some do need paint if you are fussy.
Old 04-12-2008, 08:50 AM
Send a message via Yahoo to rgofast
Jim
Tell me again which pair was 300. If they are not the corroded or cracked ones, and just need refinishing I would be interested.
Rod
1969 911TR lightweight, 1850 lb. 245 HP 2.7 short stroke
1973 1/2 911T S optioned sunroof coupe (in progress)
1998 993 Carrera Cabriolet PSS10 lowered E88 cup wheels
1999 996 Carrera Cabriolet
Old 04-17-2008, 08:31 AM
it's a sickness
Bbs
i'd be interested in seeing the pair at 300 also, i have 4 that need paint.
Old 04-17-2008, 09:55 AM
Jim,
I the centers will work to build up 17" wheels I would take 2 sets.
Old 04-17-2008, 03:41 PM
cole930, these will work for conventional BBS 20 17' halves, that's how I had them built up. I still have a pair of 17x11.5 for sale.
If you want two sets, do you mean two pairs, or eight of them? Send me a PM so I can get you a shipping quote.
The $300 pair which Rod referred to are not perfect. The are a thin section E50. One of the two appears to have had water sitting in the pocket of the wheel hub(front) between two wheel studs. I have been running it without issue. I'll look for a picture I have taken and post it up.
Old 04-17-2008, 05:59 PM
Old 04-17-2008, 07:04 PM
Jim,
I was inquiring for a friend that saw the add and called me. He told me he would take
"2 pair" if he could use them to build 17" wheels. I saw your 11.5's and know that's what he
wanted to build for the rear. He will be available by phone tomarrow and I'm sure he would
take the 11.5's and one pair of centers.
THANKS !!!
Cole
Old 04-17-2008, 07:20 PM
Jim
If the above centers are the 300. ones I will take them. I know you had a set that had mass corrosion around the center holes, and I wanted to make sure we wern't talking about those. How deep is the corrosion shown above +- 1/16 or so??. I am also still considering the old thick section E50's and may take them also. I'll PM you too.
Rod
Old 04-18-2008, 11:29 AM
PorscheX3's Avatar
Send a message via AIM to PorscheX3
Jim,
I know I am probably a little late on this, but by any chance is there a pair of the E50's left? I am now in need of a pair. Thanks, Jim
Jim
1969 911e (GT2R)
1999 Boxster
1999 996
Old 04-30-2008, 08:43 PM
PorscheX3, the centers went to two different parties, rgofast and a non member. Send rgofast a PM directly to see if he can help you out. I'll let the other person know.
Jim
Old 05-01-2008, 09:27 PM
Jim
I still have your two corroded and defective centers that you shipped along with the good ones that I bought. I dont think that I can safely use them or sell them to any one else. Do you want me to dend these back to you, or scrap them?
Rod
Old 11-01-2008, 02:57 PM
