1991 Turbo FOR SALE
Im selling
I Have a LOT into it but have to let her go. $50K I have over $80K into her. You guys know what parts cost!!! She has 71K on her ticker but a full rebuild was done at 65,800 and she is better then new. Read away!!!The 1991 Porsche 911 Turbo “965” Polar Silver in color with black interior. The paint is what I would say 7 out of 10 it has your typical small road dings. There is one small chip on the passenger rear fender the pic will show it. The outside is very clean. I have all the docs when I got car and what I have done to it. She is hard to describe other then Amazing. Starting with the drive train. It has a 3.3 liter Turbo engine that just had a full all out rebuild by Imagine Auto and not because it needed it I just wanted a little more from her. This car is babied. http://www.imagineauto.com We did a dyno after work was done and she is pushing 415HP at the wheels. I have the sheets for it. I will try to list some of what was done but it was all in on this girl of mine. Full street performance valve job, Main Bearings, Oil pressure switch, Rod bearings, Intermediate shaft bearings, Timing chains, Chain rails set, Valve guides and stem seals, complete piston ring set, ARP rod bolts and nuts, ARP 4206 head studs, Piston pin clips, Oil return tube and seals, Main seals, Oil pump seals and lock tabs, Oil cooler seals, Cam key ways and pins, Case O’ rings, Head copper shims, Upper and lower valve cover gaskets, all other gaskets and seals and crush washers. Rebuilt the Fuel Distributor to boost flow rate. It also has a C2 light weight Flywheel with a C2 LW stage 1 Clutch, Pressure plate and release bearing. Bilstein PSS9 Fully adjustable gas 9 way shocks installed and lowered to Euro specs. HR P3.6 Porsche rims with Bridgestone 225/40-18 in front and 285/30-18 in back. High Flow TurboS GHL SS full exhaust with CAT bypass. IA high air flow intake system Tail wastgate WG46.8 46mm 1 bar spring. Brand new rebuilt steering rack with boots and ends. The inside is very clean the seats are not torn or ripped with very clean soft leather. The dash and carpets are clean no rips. The inside is very nice and clean It has an Alpine CDA-9851 MP3/WMA CD Receiver with an Alpine MRP-T240 Amp with MB Quart Qline Speakers in front, sounds great. I can’t say enough about this car other then I hate to part with it but life has its changes and I have to roll with it. There is so much in this car to list I can’t list everything just know you are getting an unbelievable car. Any one with questions please ask. Cell# 847 980 7958 ![]()
1991 Turbo Polar Silver. 415 HP of pure FUN Last edited by Diverwes; 11-15-2008 at 06:12 AM.. |
1991 Turbo Polar Silver. 415 HP of pure FUN |
I have to stop driving this car as I don't want to sell it after I get behind the wheel.
Some work shots.
Any questions?
Gone
1991 Turbo Polar Silver. 415 HP of pure FUN Last edited by Diverwes; 12-16-2008 at 10:54 AM.. |
