FS: 72T MFI throttle housing
I have 1 throttle housing with a broken ear. It also has a small gring mark under the intake manifold flange. Other than these two defects it is in great shape with very minimal corrosion. Replace your corroded housing cheaply.
$35.00 plus shipping. There is stll enough material on the ear to bolt to. ![]() You can see the grind mark on the lower left side of the pic. Defect cannot be seen when installed.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ Last edited by BURN-BROS; 07-13-2008 at 09:53 AM.. |
