FS: 1973 Porsche 914 2.0 $3100
I am selling a '73 2.0 914 with fuel injection.
The good: - 911 front suspension - factory swaybars front and rear - boxed trailing arms - poly bushings front and rear - 944 front brakes - 19mm master cyl - re-bushed pedal cluster - chassis stiffening kit installed on right side (previous owner did not get around to installing l side, but I have it) - heavy torsion bars (21mm I think) and 180lb rear springs - Bilstein Sport shocks all around - has original fuel injection - 16 x 6 Fuchs with nearly new tires - new wheel bearings - 930 cv joints - comes with a new cheapie black carpet kit, new AA 2.0 pist/cyl, aftermarket new weather seals, Hirschman antenna. The Bad: - it's leaking a lot of oil and has been for a while. I'm including a good used pair of valve covers and gaskets (I think this will clear the worst of the leaks) - I have the under-dash piece - Paint is very faded. Will buff out but it is not great - passenger door handle doesn't work. I bought the plastic part for that fix; included - I have not driven it much at all because ofthe leaks, but think the clutch has some oil on it; it judders occasionally from a standing start; I'm including a used clutch disk and pressure plate. - It quits on occasion. Previous owner believed it was an intermittent fuel pump; a used one is included - Hell holes have rust and the battery tray is loose; a new tray is included - The interior is pretty shot. The center console vinyl is pulling at a couple seams. No back pad I'm sure I've forgotten things good and bad, but obviously it should be seen in person. I'm realizing that I have no time to work on it and won't for the foreseeable future so it's time to sell it. It's a reasonably solid car that is a bit of a project depending on what you are looking to end up with. But is has had some good additions already made to it. The car is in San Diego. I have other pictures if you are interested. Email me direct at augstm@flash.net $3100 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
bump
