Bird. It's the word...
Fishcop's Avatar
Successful #8 Bearing Oil Leak Fix
Hi Guys
I built my engine 5 years ago, but screwed up the #8 bearing (no sealant) when I put the cases together. It was leak free for about 3 months, but after that it's bled oil ever since. Recently it became worse and I felt it had become unacceptable. The repair normally requires the case to be split...
I thought some of you may be interested in my successful fix of a leaking #8 bearing - the O ring, not the pulley seal. It's not my idea, I pinched off a thread I found here which mentioned Tom Amon as the 'brain' behind it.
It involves spinning up an alloy ring that has an interference fit around the #8 bearing which protrudes about 10mm out from the case, I also added a couple of set screws as an added measure.
Prior to pushing the ring on, I applied my chosen sealant... there's a lot of opinion ranging from epoxy, Dow Corning 730, and a few loctite and permatex products. I decided I did want something that could could flex so I went with Sikkaflex marine grade polyurethane in black. This stuff is messy, but sticks like ***** to a blanket and sets to a truly robust flexible and oil impervious medium. The ring is heated and then pushed on so that the sealant spills a bead out and totally fills the case seam and circumference of the #8 bearing. I then tweaked up the grub/set screws. After 48 hours of setting time I cranked up the engine and got it to operating temps...
So two weeks later, not a drop of oil can be seen. I'm really hopeful that this has does the trick!
Also, I found this can be done with just a partial engine drop and you can leave all the oil lines, CV, wires connected.
I hope this is searchable for anyone else that gets stuck for a fix on this problem and is of some use...
Cheers
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 06-22-2009, 03:58 AM
cycling has-been
bkreigsr's Avatar
nice one
I went through this with my 73 after my first rebuild. I was told it leaked because I did put sealant on the bearing during assembly. Go figure.
No quick fixes I tried worked for any amount of time, and eventually , after my son missed a shift on the track, the seal let go completely and it was time for rebuild #2.
yours looks good
Bill K
oh, yeah, where's the screws?
Old 06-22-2009, 05:38 AM
signature65's Avatar
You may be onto something.....making these rings for profit.
Darren
1973 911 T MFI
2005 997 Carrera
2001 Toyota 4Runner
Old 06-22-2009, 11:06 AM
Fishcop's Avatar
I'm just happy to offer some ideas for other owners... too much on to be trying to make a profit!
John Forcier
Old 06-23-2009, 07:23 PM
OZCarrera3's Avatar
Damn! Wish I had known about that fix 5 years ago!
I had a similar leak and the subsequent investigation led me to a "while you're in there" project to replace the bearing and seal that cost me the best part of $10k (a full rebuild with new P & Cs). Although someone had already had a go by just whacking a heap of liquid metal around the bearing case. The engine does look and go very though now as a result.
Good job John.
Sheldon
'92 964 Carrera 2 (Manual)
'07 BMW 335i
'76 911 Carrera 3.0 (Gone, but not forgotten)
"Give me ambiguity or give me something else!"
Old 06-23-2009, 08:01 PM
Alan L's Avatar
Well, I think that answers a Q I was about to post.
Can you change either end crank seals without splitting case. I have a friends 2.7 on bench at moment doing few tidy up jobs. If it was possible to insert new seals either end, I would.
I did put new ones in my 3.0, but the case was split. I followed Waynes recipie (sealant) - no leaks so far (3 yrs).
Regards
Alan
Old 06-23-2009, 09:14 PM
Fishcop's Avatar
Alan, the rear main seal and the front pullet seals can both definitely be changed without splitting the case. My leak is from the o ring seal around the outside of #8 bearing (and normally requires the case to be split to fix), the pulley seal is on the inside of the bearing and designed to be reasonably easy to change.
I recall your troubles Sheldon. I didn't realise the trigger was this seal. Coming to Lakeside next month?
John Forcier
Old 06-24-2009, 01:26 AM
Alan L's Avatar
Well, that is comforting, to know you dont have to split the case for those seals.
I am still a bit in the dark on the grubscrew thing too.
A sketch if not a pic might help understand what was done here - which looks pretty useful Anything that avoids spliting the case is useful.
Alan
Old 06-24-2009, 12:45 PM
bcgreen's Avatar
Is there a similar product here on the west coast for 'Sikkaflex marine grade polyurethane'?
Do you have to heat up the ring?
66 Shelby Hertz Renta-Racer
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 11-23-2013, 03:21 PM
creaturecat's Avatar
Tom Amon sells them. No?
Old 11-23-2013, 03:54 PM
bcgreen's Avatar
Curious, if everyone who went this route to fix their leak, how's everything holding up?
What was your most successful sealant?
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 11-23-2013, 05:09 PM
sikaflex rocks!
206 637 4071
Old 11-23-2013, 07:40 PM
kugelfischer's Avatar
Yep, Tom sells these.
FOR SALE - PORSCHE PARTS AND MOTORS - Welcome to Mobile Works West!
FWIW, he installed one on my engine.... And it still leaks
1973 Coupe
Projekt X (AKA bunch o' boxes full of parts)
Old 11-23-2013, 08:32 PM
Originally Posted by john walker's workshop View Post
sikaflex rocks!
Have you tried used the ring method, with sikaflex, John?
If so, what was your success ratio?
Thanks in advance.
Old 01-03-2015, 11:23 AM
bcgreen's Avatar
I talked to some of the people who went this route and a few were successful and most still had a leak but somewhat less. I even talked to the guy who did a youtube with Tom Amon, and he said his vehicle still leaks.
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 01-04-2015, 08:29 AM
Where can I get one of those rings?
Old 02-13-2015, 11:22 AM
French Import
zippy_gg's Avatar
See post 13: FOR SALE - PORSCHE PARTS AND MOTORS - Welcome to Mobile Works West!
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 02-13-2015, 03:55 PM
New idea to fix # 8 bearing leak
Another way to seal the # 8 bearing.
I have done this 3 times before, once with the epoxy, two with oil resistant sealers.
Then , I had this idea.
A silicone "washer" tightly pressed against the housing, with a fixture.
Finally no leak. 82 911sc.
A pic
Old 07-18-2015, 10:34 AM
Bump for perm fix
Old 08-15-2015, 08:11 PM
Dave Kost's Avatar
Tell us more.
Where did you get the washer?
Dave K
Old 08-16-2015, 04:20 AM
