LinkBack Thread Tools Rating: Thread Rating: 5 votes, 5.00 average.
1973 911 Rally Car for Sale
Dennis Chizma spent the better part of two years researching and deciding the exact year and the exact model he wanted for use as a Production class rally car. He settled on a 1973 Porsche 911S. He bought his 911 as a tired street car, sight unseen, from a used car dealership in Reno, Nevada, and had it shipped to him in Southern California June of 1999.
The car was stripped down to the bare bones and restored while being prepared to compete in a full national SCCA ProRally season. He really hit the jackpot on several occasions, finding Porsche parts collectors that upon hearing of his project went to the back rooms and found Porsche rally parts from that era. It was an exciting time and five months were spent meticulously preparing the car. Every part was cleaned, resurfaced and restored.
There were a few problems with the car throughout the 2000 season. The mechanical fuel injector needed to be rebuilt twice, and since it is the only part of the car that Dennis is unable to repair himself it spent some time with Federal Express being shuttled between Seattle and San Francisco. The rear torsion bar tube housing needed reinforcement after Rim of the World where it caused a DNF.
2001
1973 Porsche - DIMENSIONS & SPECIFICATIONS
Weight: 2550 pounds
Engine: 2.4 liter
Fuel System: Bosch mechanical fuel injection
Power: 160 HP SAE
Transmission: 5 speed manual, 915 transmission with rally gear ratios, rally ring and pinion, limited slip diff
Suspension: Strengthened front and rear trailing arms
Torsion Bars by Swayaway
front: Bilstein rally struts, rear: Bilstein rally shocks
Interior/Safety: Seats: Beard
Belts: Willans 5 point with F1 cam
Roll cage: Motor Sports Unlimited, 12 point
Odometer: Terratrip 303+ (with remote)
Brakes: 911S calipers
Discs - front: 282.5mm dia. vented, rear: 290mm dia. vented
Carbon fiber brake pads - F&R
Wheels/Tires: Wheels - 15 X 6 inch Fuchs
Tires - front: 195.65.15, rear: 215.65.15
Elec/Lights: PCI Intercom, PCI radio
Lights - 4 KC Hi-Lites 300,000cp
This car was purchased by Bob Olson of Minnesota in 2001. Olson converted it to SCCA Group 5 specs installing a 3.4L Carrera with a Motronic engine management system which he competed in ClubRallys and ProRallys.
Jump ahead to 2005 when I purchased the car and ran three events and then lost 4th gear in the transmission. What started as a simple pull the engine to rebuild the transmission ended with a complete rebuild and total freshening of the Porsche. The doors, fuel tank, dash and windshield were the only parts not removed, replaced or repaired. Four hundred and forty-six (446) hours documented hours were invested in the 911 not including the gear box. The gear box was rebuilt with new a case, new 4th gear set and all new bearings, Wevo shift gate coupler & Shifter, hardened bearing retainer, rally ring and pinion and a Guard Limited Slip Differential.
New since rebuild:
• New Mechanical Parts- Fuel Injectors, Idle speed adjuster - O2 sensor - Coil – Clewett Plug Wires - Plugs - Rotor – Cap – Fuel Pump - Both Reference Sensors – Cylinder Head Temperature Sensor – Throttle Switch – Micro Switch - Mass Air Flow Sensor – High Flow Air Filter – DME with Steve Wong dyno’d chip
• New Safety and Weight Reduction Items – Sabelt HANS 6 point Harnesses – Poly Carbonate back window and side vent windows – Light weight Duck Tail – TerraTrip – Motocam On Board Video System
• Suspension Modifications – Elephant Racing ASP “Adjustable Spring Plates” with Poly Bronze Bushings– Aluminum Rear Control Arms - Rebuilt Leda 24 way adjustable shocks all four corners
• Electrical – Complete wiring harness – custom fuse panel – Odyssey battery
2007
Weight: 2425 pounds
Engine: 1988 - 3.4 liter transplant
Fuel System: Motronic fuel injection (flow tested)
Power: 296 HP SAE
Transmission: 5 speed manual, 915 transmission with rally gear ratios, rally ring and pinion, Guard limited slip diff
Suspension: Strengthened front control arms and Aluminum rear trailing arms with ASP Adjustable Spring Plate Kit. Torsion Bars by Swayaway
Front: Leda 24 Way Adjustable rally shocks, Rear: Leda 24 Way Adjustable rally shocks
Interior/Safety: Seats: Sparco Carbon Fiber FIA Approved
Belts: Sabelt HANS 6 point with F1 cam
Wheels/Tires: Wheels - 15 X 6 inch Fuchs & 15x7 inch Fuchs
Tires - front: 205.65.15, rear: 205.65.15
Elec/Lights: Peltor Intercom
Lights - 2 PIAA HID – Pencil & 2 PIAA HID - Spot
Asking $ 25,000.00
Bob
Old 08-13-2009, 05:54 PM
Tags
race car , rally
