85eurocarrera's Avatar
disarm factory alarm?
I did a dumb thing a few months ago. Removed doors prior to re paint and had electric windows in down position. When I went to disconect wires I could not get to alarm switch to disconect so what do you think I did??? Yes I cut the two wires.
Now ready to move car to paint booth (I have to start it up) and drive around building. No can do!
Can I disarm this system and start it up somehow or will I have to get in and remove alarm system control module? Will car run with unplugged control module?
Thanks,
Joe
This thread might be better attached to "dumb thing you have done"
Old 05-04-2002, 07:54 AM
Early_S_Man's Avatar
Porsche Crest
You will have to remove the alarm control unit and put a jumper accross the two #61 pins in the connector. Yes, the car will operate normally without the alarm unit.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 05-04-2002, 08:13 AM
Thanks S Man!
Thanks so much< I was just going to reatach door and hook wires back up...but I am here alone at my shop. The doors are kind of a pain to install.
Joe
Old 05-04-2002, 08:22 AM
What 2 # 61's
Help. where are my 2 #61 PINS ? I can see the one marked 61, but which one is the other? Did they renumber it on me.
david 89 turbo cab
Old 04-04-2004, 09:54 AM
Hello Joe,
maybe its easier when for ya, when i named the wirecolor-codes.
Listen: look for the 2 wires Blue and Blue/Red these are the ones.
Good luck,
Andrew - 9elevenNL
The Netherlands.
Andrew:wanna convert my 87- 911 to 964 C2-look.
Old 04-05-2004, 06:30 AM
Cool here a piece of the wiringdiagram !
And promise never to cut wires.....
Greetz
Andrew
The Netherlands.
Old 04-05-2004, 06:34 AM
Heck, I’m only 5 not 71!
targa80's Avatar
Looks like they changed the codes on the module. On my 1980 alarm module there are two # 61 contacts.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 04-05-2004, 07:20 AM
Hey Pat,
How is da Restoration goin'!
regarding th 2#61 connections:
That's has to be the same, or else the wiring would be the same.
Only the Alarm Module would't be modifide.
I've looked at a wiringdiagram from before 1985, and one unitl 1989.
Both wiringcodes stayed the same.
So, it must be ok.
hahhahahaa...
When is the Targa finished?
Greetz
Andrew
Old 04-05-2004, 08:00 AM
Series900's Avatar
You can also add a resistor between the cut wires at the alarm switch, therefore giving the 5 volt resisted signal back to the alarm box
Damon @ SERIES 900.com
Sunapee NH
several 911 variants
Old 04-05-2004, 08:15 AM
Porsche Crest
David,
Looking into the two connectors at the wiring harness ...
The SC alarm unit is labeled slightly different, and different pn, too:
30 ; ; E/A , MK , 61 , 61
Hn ; ; 15 , T- , 31 , K1
So, it looks like to bypass your unit you would jumper your #61 and 'A' terminals at the connector.
Joe,
To clarify what Series 900 posted ... the specific resitor to use would be 4000 Ohms to 5500 Ohms between the cut door switch wires ... that specifies alarm unit OFF! A 2000 Ohm - 3000 Ohm resistor specifies alarm unit ON!!!
Warren Hall, Jr.
Old 04-05-2004, 10:48 AM
Series900's Avatar
I created a supplementary system to the factory alarm, utilizing off the shelf remote transmitter, added remote locking and remote activation of factory alarm this is where I used the resistors to fake the alarm key lock. I added a hidden switch to "Y" off the alarm switch in the trunk. Pretty cool features were delayed switching of the interior lighting, I seperated off the glove box light form the negative trigger of the door switches. The negative triggers of the door are needed for the alarm and therefore could not be used for delayed interior lighting. A well regarded Pcar stereo/alarm told me it could not be done. I did it. The fail safe is the hidden switch to go back to factory key switch, and not get stranded with a no start.
Sunapee NH
Old 04-05-2004, 12:51 PM
targa80's Avatar
Originally posted by 9elevenNL
Hey Pat,
Greetz
Andrew
I'm a turtle and not a rabbit when it comes to working on the Targa. Just finished stripping the bumpers and flag mirrors. Should start Por-15 and primer soon.
Joe, I apoligize for stepping on your thread.
Pat Henry
Targa80
Old 04-05-2004, 12:52 PM
No need to appologize, this thread was started over a year ago.
Yor resto looks great! Glad to see you keeping it brown. Mine is nut meg brown mettalic, grows on me all the time.
Joe
P.S. why has my post count stayed the same? Have I gone back in time?????
Joe
Old 04-05-2004, 02:31 PM
A big thank you all around. The willingness of the experts to help out guys like me makes pelican something special. Warren your the best!
... awwww group hug...
david 89 turbo cab
Old 04-05-2004, 03:32 PM
targa80's Avatar
Joe
And I thought this was a new post. Sheesh I guess I don't pay attention to the details. But I tell everyone else to pay attention to the details. Oh nuts!
Pat Henry
Targa80
Old 04-05-2004, 06:50 PM
S2GART's Avatar
I know this thread is very old and probably forgotten, but I could use some help with my stock SC alarm system and this thread seamed the most useful, but I still have a couple of questions.
I am looking at the wiring diagram out of a Bentley's repair manual for the SCs. It shows 2 pins numbered 61 and they go to the alternator and Battery charge indicator. Why they go there, I don't know, but why would jumpering these as suggested, take the alarm system out of the loop.
I have not pulled everything part to get a look at the unit in my car to see if it indeed matches this schematic.
Early S Man suggested jumpering #61 and "A" terminal. Which one of the 61s and which A? Per my diagram, there is an "E/A" and a 87a.
Thanks for revisiting this old thread.
The "collection"
1983 911 SC Targa (1 of 1430 imported)
1994 MB E320 Coupe (1 of 825 imported)
1992 MB 190E 2.6
2004 Volvo V70 2.5 Turbo (1 of a bazillion imported)
Old 04-09-2011, 03:22 PM
I am looking at this problem as well.
Lorne M.
83 SC
Old 08-05-2012, 10:23 PM
Kevin.'s Avatar
Where is the Alarm module on these cars, and how do you get to it???
Old 09-12-2012, 07:00 AM
Module is on the passenger side underneath the fresh air blower. You get to it from the trunk by removing the fresh air blower.
John
'86 911 Coupe
Old 09-12-2012, 07:06 AM
Kevin.'s Avatar
That's what I thought but wanted to make sure...
When the alarm activates, what lights normally flash?
I have an 89 911 and the brake lights flash along with the
fog lights. Does this sound 'normal'?
Old 09-12-2012, 02:16 PM
