entertaining the idea
UconnTim97's Avatar
Question cooling fan relay
I am currently trouble shooting why one of my cooling fans is not working(even with AC on--only one fan) It seems to be the relay. The problem is, when I turn on the AC, I get a burning odor and small amount of smoke from the relay/fuse panel (All of the fuses are good). Is this a sign of a bad relay. There is no odor without the AC on.
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 06-29-2003, 07:32 PM
did you swap the fan connectors to be sure the fan is good?
if yes...then prolly relay's coil windings are starting to 'short out'
Tom
Early '85 944
Old 06-29-2003, 07:43 PM
UconnTim97's Avatar
I didn't swap the wires yet, but I checked the conections and they are still good.
Old 06-29-2003, 07:47 PM
Send a message via AIM to TheCooler
I had a burnt odor coming from my fuse box but nothing was wrong ...stupid electronics. I would say check the fuses again. hehe
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 06-29-2003, 09:09 PM
When you go to replace your relay, be aware that the factory documentation is wrong.
Most parts places will sell you the wrong relay. In fact, if somebody has replaced the fan relay with the factory reccomended part, that could be why only 1 fan is running.
pull the 1st and 3rd relays http://www.frwilk.com/early944/misc/relay.htm
Grab a flashlight, and count the copper contacts inside the 1st and 3rd sockets. The first socket should have 6 contacts, the correct relay part number is: 944.615.113.01 The 3rd socket should have 4 contacts. the proper relay part number for the 3rd position is 141.951.253B
The factory documentation has these relays switched. The reason i say count the contacts, is that it could have been a mid-model change in the early cars. I know of at least 4 cars (mine included) that the above information is correct. BUT.......it is possible that in very early cars the factory documentation is correct. Please reply with what you find out. I am trying to figure out whether the documentation is wrong for all early cars, or just a select group of early cars.
Mike
Old 06-30-2003, 06:53 AM
UconnTim97's Avatar
I just ordered the relay from pelican yesterday. It should be here in a few days. I'll let you know when it gets here. For the record, I ordered the part number 141.951.253B, like the manual said. Thanx for the info.
Old 06-30-2003, 03:27 PM
UconnTim97's Avatar
I just ordered the other relay just to be safe. I might as well replace them both while I am down there.
Old 06-30-2003, 03:33 PM
UconnTim97's Avatar
I found out the fan was bad, jumpered it directly. I ordered a new one. Should have it fixed next week, and replace the relays while I'm at it. Thanx for al of your help.
Old 07-01-2003, 07:33 PM
UconnTim97's Avatar
mike944, you were correct about the relay information....thanx
Old 07-23-2003, 09:18 PM
good to know stuff about the relay part numbers...this is 'a keeper'
and to test the fan first ;-)
Tom
Early '85 944
Old 07-24-2003, 07:13 AM
Official Sponsor
vital-transform's Avatar
I have both relays???... got the new one from the porsche dealer part #141 951 253 B
the old one is 944.615.113.01
the parts guy showed me his book that showed the 141 951 253 B as the correct relay for my cars cooling fan to answer my question as to why it was not the same as the old relay...
I have not used the new one until now that I suspected thet my old one was bad when the fan stopped working, I am going to get a new 944.615.113.01 and I bet that all will work fine when I do...the 141 951 253 B is used elsewhere as well so it won't go to waste
and I am still going to install my own SPAL emergency and very hot day fan on the front of the radiator to be controlled from the cockpit!
I am looking for a 12 volt power source right now to test this !$#^&*? relay
1988 - 924S Guards red, auto trans
Old 03-25-2004, 09:39 PM
tobster1911's Avatar
Try Radio Shack. You can get a real nice 12 Volt regulated power supply for about $17. Uses wall outlet and you get your choice of tips.
'97 Saturn SL (tiny 1.9L bubble car)
'98 Grand Prix GTP (4dr family car with a bite FOR SALE)
'87 944S (Sold as a German engineerd money pit)
'78 Chevy 4x4 (What I drive when everything else is broke)
Old 03-26-2004, 08:47 AM
Official Sponsor
got the new correct relay for #1 - 615 113 01 installed it still no drivers side fan at any time?
except both fans will now run with the a/c on ( I found a loose wire at the fan plug that was preventing contact to the passenger side fan)
key off = no fan
Old 03-27-2004, 08:31 AM
