Hey!
Trying to find a supplier or at least part no. for a gasket which goes in a cover plate which attachs to the S-tube in the heater circuit on a '74 2.0. Is anyone familiar with it and does anyone know where to buy? Thanks! Mike
VOPO '74 2.0 Last edited by Mike Kunz; 07-22-2003 at 08:35 PM.. |
branch clamp gasket 021.256.326A and 021.256.325A
found on the dreaded Dr's web site. why not try cutting some out of gasket material?
73 914 restoration project 73 914 2.0 CIS #80 74 914 1.8L L-jet 83 911SC |
a small bead of rtv should work fine. just let it cure over night before firing things up.
kevin
here? not so much i think. high five!!! |
Whoa, I didn't know there was a gasket there??!! Our 1974 has been running for years without them and seems to have little affect? I agree with the small bead of sealer. Good luck.
I cut a replacement out of cork. Unless you live in Greenland, I don't think you would ever notice/need that extra bit of seal to prevent heat loss. The greater benefit would be the elimination of one more rattle from under the car. I think they all blend together to form one harmonious 'bzzzzz'.
Herb '72 Tangerine 'Teen 2.4 liter aluminum handgrenade |
keeps out moisture and oil/grime issues. every sealed fixture helps out with heat. ours heaters should melt vinyl records with a maintained system. also look at the paper tubes behind the speaker enclosures. ever notice bits of paper comming out of the vents when the bellows/valves have been closed for a while?
kevin |
