runs bad at idle
the car hasn't been started in about 2 1/2 years and i just bought it. It had a bad fuel pump and i replaced it. I got the car to start and run, but it just lopes in the lower RPM range and won't idle. it shuts off when you take your foot off the gas. I had it running for about 20 minutes to see if it was bad gas or something, and i noticed alot of smoke entering the cab of the car from beneath the floor. So i looked under the car and the cat was glowing red hot. I immediately shut the car off and have no clue what could cause it. can somebody help?
1986 944 non-turbo |
Feelin' Solexy
Cat going red hot means you need a new cat, the one you've got is fouled up. Not sure is a cat can get so fouled up that it would effect your idle though......doesn't seem likely to me.
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
is that causing the idle to run choppy?? and the response time to be horrible?
was there exhaust coming from the tail pipe??
The CAT may be clogged.
83 944 with 87 engine 5-speed LSD burnned |
yeah...it was pretty smokey and black...but exhaust was coming out!!!
Let's go shooting.
Could just be a poor engine to firewall ground - even good clean looking earths can prove to be wanked. Try putting a booster cable across the neg terminal of the battery and the firewall earth to see if the idling picks up.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas 1991 944 (automatic) 2.7 litre 16 valve na and pas "I have only five words for you: From my cold, dead hands." |
I would agree with removing or replacing the cat. Also you might want to replace the O2 sensor and have the fuel mixture set.
Roger Hall 81 924 N/A Some people are like Slinkies. Not really good for anything, but you still can't help but smile when you see one tumble down the stairs. |
Better check for a rats nest in the exhaust.
You did change the timing belt before starting it.
no i didn't change the timing belt, but i will look at it
Or the CAT will not be the only thing that is glowing red. Remember a new too tight timing belt is better than an old ready to break timing belt. You can get it adjusted later. Same for the balance shaft belt.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! Last edited by SoCal Driver; 10-23-2003 at 09:33 PM.. |
how can i check the vacuum to my fuel regulator?
the car has been garage kept those past 2 1/2 years...it hasn't been exposed to any weather...are you sure the timing belt is the reason? cause it looks good to me!
The timing belt is secondary to your problem. If you have not turned the engine over during the storage the bends in the timing belt as it goes around the pulleys take a "set". That is the belting strands will move inside of the rubber and tend to stay in a bend when the engine is run again. This causes heat build up as the bends are straightened and possible premature failure of the timing and balance belts.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! Last edited by SoCal Driver; 10-24-2003 at 08:18 PM.. |
Birds, mice, insects can get in a car sitting that long. In addition, when you start up, a motor sitting that long is going to probably smoke a bit while it burns off dried oil and varnish, etc., that was in the system, including some of the old gas that has almost turned to varnish. It will smoke. WHen this smoke goes to the cat, the cat gets hot trying to burn it up.
You might try again a couple times watching the cat closely. If it continues to get hot like that, you do need a new one. Beware, the factory cat for a 944 is $1500, but if you do a Google for "catalytic converter" you can find one for the 944 for around $150. I'm running one right now, it makes the car sound a bit better, passes the smog test, and saved me a bunch of money. It's not stainless steel like the stock unit, but hey, for the price it's a deal. good luck, P Nashville
1983 928S 5-speed, 1984 944, 1990 944S2 Cabriolet My other car is a Chris Craft Commander http://www.chriscraftcommander.com |
i'm not a complete idiot...but just so you guys know, it was the spark plug wires! The guy i bought the car from said he changed the plugs and the wires before he parked it, so the whole time i'm thinking that its a sensor, or something not very obvious. Pistons 1 and 4 weren't firing and i removed both of their spark plug wires and the engine never changed sounds...and i know its not the distributor cap or rotor cause the dist. is firing fine!! now i have to pay that outrageous price for plug wires! can somebody tell me why their so expensive???
i checked that too...their in the right order and their on correctly...i even found an old set of spark plug wired and rigged them so they would fit the car...and it ran ALOT better...but still not perfect...cause the wires i put on their worked, but they were old!
cat glowing hot red means toooooo much unburnt fuel entering it you probably melted down the center of it . mazda rx7 style .
the plugs are brand new...i just bought them the other day!
Feelin' Solexy
Are the plugs gapped correctly? Are they (duh) the correct plugs/temp/etc for the engine you're using? Are you sure they're firing at all? You can test the spark by using another plug plugged into the spark plug wire and holding the threads to the body of your engine (like the manifold) while the engine is running or cranking over.....you should be getting bright blue spark. If not, look at the plug wires, and possibly the coil, which you can test using a multimeter. Also, as someone said before, what do the plugs look like in the cylinders that aren't firing? Do they look fouled up, etc? Although with the very limited time the engine has been run, the look of the plugs may not be a trustworthy indication.....
I can't believe that you could run an engine on just two cylinders and not know it.
