cnielsen's Avatar
Question looking for good info on 3.2 swap into an early car
I have tried searching the archive but I did not come up with the kind of info I was looking for. Does anyone have any good info on installing a 3.2 into a '69-73 chassis. Mainly, I am looking for wiring help. What does it take to hook up the brain to the rest of the car? Any other pitfalls to look out for???
Thanks, Chris
Old 01-13-2004, 04:39 AM
IROC's Avatar
Having swapped a 3.2 into my '76, I'll throw in my two pfennig. Interfacing the "brain" with the rest of the car isn't that difficult, really. All you really need to do is get a couple of 12V power sources (from your fuseblock) to the DME/DME relay. The DME really only connects to existing components on the engine itself and not so much into the rest of the car (aside from the above mentioned power needs and a connection to a tach).
What you will have to sort out is supplying fuel to the engine (not a huge deal, really) and sorting out the wiring from the engine that controls the starter and all of the signals from the various sending units. Porsche seemed to be relatively consistent on wiring of gauges, etc., over the years, so this is also not a *huge* task.
My advice would be to gain a good understanding of what connections exist on the 3.2 (gauges, power, tach, starter, etc) and then figure out the best way to interface them with your particular car. In the end, it's probably not going to be as bad as you think.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 01-13-2004, 05:00 AM
cnielsen's Avatar
What is difficult about the fuel supply? I will probably need a carrera fuel pump but what are the other problems? Is it a circulating system or just a supply line? Do I need any of that "stuff" that is found on the left engine bay of a carrera? Accumulator???
Chris
Old 01-13-2004, 06:13 AM
IROC's Avatar
Nothing difficult - just things to sort out. The fuel supply from the pump needs to interface with the fuel filter in the engine bay and to make that happen on my car, I had to fiddle around with some fittings to get it to work.
Plus, you'll need to adapt the fuel return line from the engine to the tank. On my car, I simply cut off the threaded fitting that comes out of the fuel pressure regulator on the 3.2 and replaced it with a barbed hose fitting and then ran a new fuel line down to the threaded return line on my car.
Nothing major - just things to tend to...
Mike
Mike
1976 Euro 911
Old 01-13-2004, 09:24 AM
Sports Purpose 911 Driver
mjshira's Avatar
send me a PM and I'll give you my number
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 01-13-2004, 09:48 AM
kiesan's Avatar
Hey Chris I noticed you're in Seattle as I am. I have some 3.2 Carrerra stuff (Fuel rail, DME wiring harness) left over after I converted my car to PMO carbs and Electromotive. If you need it let me know and I can sell it at a fair price.
Kie in Seattle. '05 3.4 987, '76 930 DP/Kremer thing. Past p's... '91 928S4, '95 993, '82 928, '91 944S2, '92 964, '67 912/911 2.7, '72 911/3.0, '89 951, '87 951, '94 968 cab, '96 993, '87 928S4, '78 911SC targa, '79 911SC, '84 Carrera row, '75 911S, '85 Carrera targa, '84 930 RUF, '04 996 C4S.
cnielsen's Avatar
Thanks Kie and everyone else! I will try to sort things out. I have not tried the transplant yet but want to eliminate any surprises when I do!
Kie, sounds like we have some similar interests...Ducatis and Porshes. I'll definately contact you if I need any of those 3.2 parts!
Chris
cnielsen@u.washington.edu
Old 01-13-2004, 09:56 AM
chuckw951's Avatar
Re: looking for good info on 3.2 swap into an early car
Thanks, Chris
Chris,
I believe the wiring for the 69, 70/71 and 72, 73 is different and would also vary depending on where the car in question is a 911T or 911E/S. For 1969 there is no 14 pin connector for the wiring harness for the engine/gauges, but rather a set of 3 or 4 6pin plugs behind the motor. Seems to me that the 3.2 conversion would be easier with a 70+ car because you already have the 14 pin connector in the engine compartment. I've seen a "pin out" diagram for 3.2 motors posted on the internet. Wiring diagrams are available from pelican parts pages.
Another thing to consider is that the early cars had an alternator with an externator regulator where as the later cars had a an alternator with an integrated regulator so that should make the wiring a bit easier.
You'll also need to consider your transmission choice. The 69 901 will not bolt up to the 3.2 without a special flywheel, but the 70/71 901 and 72/73 915 will. The 915 would be the preferred transmission for the 3.2 because it can handle the torque. (edit: note that some mods might be needed to the transmission for the sensor pickup which I'm not familiar with)
You may need to install early sensors on the 3.2 motor so that the stock gauges (oil temp, pressure) work or I suppose you could update to later gauges. I don't think the stock early tach will work with the 3.2 motor.
Adapting the fuel lines shouldn't be too hard, but again that will vary depending on the year of the early car and whether or not it orginally had carbs or fuel injection and if the 3.2 motor needs a return line. I'm not sure where the fuel pump is for the 3.2 cars. But please check the quality of the fuel hoses. The early cars had lower pressure fuel systems than the SCs and Carreras.
Which exhaust are you using and will it have an O2 sensor? I believe the fuel ignition needs that sensor.
Finally you may consider back dating your heating system by using the early engine tin on the 3.2 motor.
I know I haven't provided the really specific info you're looking for but hope I've outlined some things to think about as the project moves forward. I don't think anyone has written a comprehensive 911 hotrodding book yet.
1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler
Old 01-13-2004, 10:30 AM
Rick Lee's Avatar
I participated in this 3.2 swap. JW helped out by phone too.
http://www.pelicanparts.com/MotorCity/marcesq1/
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 01-13-2004, 11:40 AM
chuckw951's Avatar
There are so many "small" issues with these swaps. I didn't even think about notching the bellhousing or that the male 14 pin connector would have to be moved forward. Great project.
In my last post I don't raise issues with the oil cooling system. For my swap I used an early engine cooler on the 3.0 motor so that the S oil line from the cooler to the early oil tank could be used. I did need a special line (flexible hose rather than hardline) from the oil scavenge pump above the trans to the oil tank.
So I think if you are installing a 3.2 into an early car you need to think about the cooling system. Did your car come with a front oil cooler?
Old 01-13-2004, 12:01 PM
cnielsen's Avatar
Wow, thanks for this link!!!
This goes into the wiring details and fuel/oil line details that I was looking for. Even though this was not for an early car, I think most of the info can be applied or at least help for a better understanding.
Thanks!
Chris
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 01-13-2004, 04:32 PM
I am looking at doing a 3.2 into a 69 911S. I would like to try this using the stock 901 trans if possible. With that in mind, what is the special flywheel that is needed to mate the 69 901 to the Carrera 3.2?
Bill
Old 12-02-2004, 02:40 PM
Green Skull 006
Jim Garfield's Avatar
Bill, did you just get that 3.2 yesterday? Seemed like a good deal if it's the one I'm thinking of. I was thinking of bidding but the local pickup was a problem.
I think that PowerHaus? in Arizona might do that flywheel.
If you don't mind me asking, what is the header/muffler setup on that engine? Sportmuffler?
S Reg 823 R Gruppe 246
1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha"
"It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field.
Old 12-02-2004, 04:29 PM
Patrick motorsports sells flywheels for that application. Just don't do any drag race starts in first gear.
Phil
Old 12-02-2004, 04:35 PM
Green Skull 006
Oops, Patrick is who I was thinking of.
Old 12-02-2004, 04:43 PM
randywebb's Avatar
Right, as does Kennedy.
__________
You will need to put the old oil press. sender in the spot near the breather cap (there is an oil temp. idiot light sender there now).
I also found that my oil temp. gauge does not work. I haven't figured out why yet. If anybody knows whether the 3.2L sender is or is not compatible with the '73 gauge, pls post.
You will need to move a few wires in the 14 pin engine compartment connector.
If you keep the DME, you are out of my league.
- Ferris Bueller's Day Off
Old 12-02-2004, 04:44 PM
randywebb's Avatar
Oh - one other thing - I posted a few months ago about how to make an adapter for the trans. so you can use the 915 style trans crossbar with the nice replaceable rubber -- or Wevo -- mounts.
Search it up.
Old 12-02-2004, 04:49 PM
randywebb's Avatar
couple of corrections to a post near the top:
- the stock 1973.5 tach will work with the 3.2 motor just fine, at least using a MSD box - just run the tach wire into the end of the box
- the 911 type trans uses a 225mm clutch; it still needs a special adapter flywheel, I think.
Old 12-02-2004, 05:10 PM
Jim - yes I went ahead and bought that 3.2. I have yet to see it, but it supposedly has all the parts for transplant into an early car (other than the fuel pump and lines, and the ECU and harness are there any other parts I should look for?). It does sound like I will either need to get the special flywheel or a 915. As I have seen several 915s go for less than $1000 and the 3.2 includes the pressure plate and clutch kit for a 915 it may be cheaper (and certainly more durable) to go this way.
Akkurat, the shop that has the engine, was unsure what the headers were. They said they look like production fabricated headers, as opposed to one off custom jobs, but they did not see any manufacturer marks. They have no heat and are said to be of excellent quality. To be getting 224 RWHP out of a basically stock 3.2 those headers must be doing something right. TThe muffler looks like a standard sport muffler from the pictures. The prior owner wants to get more hardcore at the track and is going to a 3.6 or 3.8.
I am going to look at the engine and parts tomorrow and can take some pictures. It will likely be a few days before I bring it home.
Any advice on the 3.2 swap is appreciated. I presume the external cooler on my 69S should be sufficient for the 3.2 as it is about the same as what was on the Carreras.
Bill
Old 12-02-2004, 06:11 PM
