ischmitz's Avatar
16x8 Fuchs on a narrow-bodied Targa
I just wanted to share a little success story in my ongoing quest to get the Targa more suitable for the track.
We installed 16x8 Fuchs 951 in the rear with 225-50-16 Kumho MX and put the 16x7 with 205-55-16 to the front. With the addition of a duck tail and a strut brace the car is totally transformed. It turns in great, corners awesome and at high speeds the stability is greatly improved. As a bonus I get much better cooling. A well-known capacity in 911 expertise opened his bag of tricks and did a great job to get me closer to a track-ready everyday-driver. Willow Springs I am ready.
Cheers,
Ingo
Old 05-18-2004, 08:47 PM
PRO Motorsports
Tyson Schmidt's Avatar
Boy, whoever helped you with your car must be a GENIUS!
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 05-18-2004, 09:15 PM
I guess the camber has to be adjusted to fit properly.. I would like to do 7 X 16 on all 4s because the SO-3s w/ 6 X 16 raised the car about 3/8in over the same size, 205 x 55, RE-71s.. But I don't want a camber that'll wear the tires. I gotta be able to rotate tires when I go for a ride is why I need all 4 the same size.
and Tyson..
I'm presently doing the carb plumbing as per your advice of a continuous loop. I'm using the Holley fuel regulator after the carbs/ before the return. I also found a large 5# gauge. Richard Parr wants a pic when completed for Maybe using the pic on his site. Thanks again for straightning out what I need to do.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-18-2004, 09:32 PM
}{arlequin's Avatar
so what does the 951 difference translate to as opposed to a regular 911 8" wheel?
dave
1973,5
Old 05-18-2004, 09:37 PM
PRO Motorsports
Very cool Ron! I hope it goes well.
Yeah, I had to crank in about 3 degrees negative camber for clearance. But dang, that thing oughta stick in the corners now!
2004 GT3
Old 05-18-2004, 09:41 PM
nostatic's Avatar
yeah, but I think he's one of those *evil* ones...
Old 05-18-2004, 09:43 PM
RETIRED
Joe Bob's Avatar
Should get about 3,000 miles outta them Kumhos.....%^B
2012 ML350 3.0 Turbo Diesel
Old 05-18-2004, 09:54 PM
ischmitz's Avatar
As long as they are FUN miles I don't give a $hit
Old 05-18-2004, 10:34 PM
ischmitz's Avatar
They extend more inboard due to its smaller offset.
Old 05-18-2004, 10:36 PM
marcesq's Avatar
Actually the offset on the 951 wheels is 23.3mm and the offset on the 911 is 10.6mm, but the effect is push the wheel inboard, ljust like a 7x16.
Nice work, I could only get a 225/45-16 in.
How much neg camber do you have, and how is the oil line clearance??
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 05-19-2004, 08:39 AM
KTL KTL is offline
Schleprock
KTL's Avatar
-3 degrees. OH yeah.
I think you're going to like those Kumhos. I feel they're excellent tires. Compared to other tires i've driven on in the 911 (Goodyear Gatorbacks, Yoko ES100, Sumitomo HTRZII, Dunlop 4000), these tires have much stiffer sidewalls and are much more responsive. Grip is great and they start with a bit less tread depth than your typical tire. Excellent tire for the money in my opinion. And they look cool. Wish more people would try them! Be sure to post your impressions of them to enlight other people.
Oil line clearance should be fine. Had no problem on my car with the same basic wheel (actually a 16x8 +23.3mm o/s 951 phone dial) shod with a 245/45 Yoko ES100.
Kevin L
'86 Carrera "Larry"
Old 05-19-2004, 08:50 AM
MichiganMat's Avatar
Send a message via AIM to MichiganMat
I wish I could have seen this thread _before_ I stuffed my 15x8 Fuchs under the rear of my narrow body Targa. I could have saved myself the horror of denting the crap out of my fenders from the rolling. Ah well, whats done is done. Amazing how much of a difference an inch makes in the feel of the car though, huh? The 15x6s made it drive like a wet-noodle, but the 7s and 8s transformed it into a rock-solid autobahn burner.
m.
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
'99 LR Disco 2, gone but not forgotten
Old 05-19-2004, 09:08 AM
Iscmitz and Marc:
So if the *offset* is the same...then the *backspace* for the 1" wider rim puts all of that extra width on the inside......
---Wil
Edit:
I need to make a correction:
8" 911 piece is 10.6mm offset, 112 mm backspace
8" 951 piece is 23 mm offset, 125 mm backspace.
If this is true...then the 951 piece places the wheel about 13mm ( say, 1/2") closer inboard than the 911 piece.
Sorry....
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 05-19-2004, 10:08 AM
Bill Verburg's Avatar
No, o/s is the distance from the wheel centerline to the hub mounting face.
look at the 2nd and 4th from the bottom wheels in this diagram.
They have the same o/s but one is 1" wider than the other.
Bill Verburg
Old 05-19-2004, 12:05 PM
Bill:
I think your post and my correction crossed in cyber space...
--Wil
Wil Ferch
Old 05-19-2004, 01:35 PM
Eric Mckenna's Avatar
He has devised a way to install 8" fuchs on a narrow body 911.. "BRILLIANT!"
Eric
Famous last words..
"Hold my beer and watch this...'
" The reason the Irish are always fightin one another is that there are no other worthy opponents ".
Old 06-23-2004, 09:07 AM
Administrator
Jack Olsen's Avatar
I run a little more than 3 degrees negative, and drive the car about five days a week on the street. I'm always surprised by how even the wear is, considering.
Maybe the secret is to avoid straight roads at all costs.
Old 06-23-2004, 11:38 AM
Licensed User
Shuie's Avatar
Nice job Ingo! How much room to have left between you tires and the spring plates?
Have you guys seen the custom 2 piece 8s on the front of Mark's Duck? Bigger offset, pushing more of the wheel inside. I think they would work on the back of the narrow arse cars without too much trouble.
Old 06-23-2004, 11:46 AM
}{arlequin's Avatar
Which Mark's? Any pics? Dimensions?
dave
1973,5
Old 06-23-2004, 12:05 PM
Licensed User
Shuie's Avatar
No dimensions, but check out the red SC in this post for some pics
Need some opinions on Fuchs sizes, maybe some pics?
Old 06-23-2004, 12:20 PM
