brake/oil cooler intake question
I keep the running lights out of my car...thinking that I get better air-flow to the oil cooler.
Does anyone make a GRP or carbon fiber air scoop intake that I could put in the empty hole. I've seen the ones that fit on the side ...not looking for that. Thanks in Advance
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud) '70 914/6 Race Car (Faster and Louder) '71 73RSR tribute vintage race car 3.0 '68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox '81 Magenta IROC clone in progress 3.6 varioram/G50 |
not that I've seen. Don't think so. you could make something, though.
Andy |
nice car,is your oil cooler on the left?lf you`ve ever done any fiberglass work that would be the way to go for ducting,but it`s a time consuming process.Or sheet plastic and a heat gun/plastic welder can yield good results also
my life begins at 150MPH |
disband
i found these intake scoops at io port racing. i got a carrera valence with recessed fogs and did some trimming and epoxied them in. in hind sight i wish i would have painted after the duct install instead of before, but oh well.
they work very well. i deverted the air right into the cooler area with ABS waste pipe fittings.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
disband
oooppps here the pick
Hilbilly Deluxe
Mine is a little lower tech:
![]() Tom |
my oil cooler is on the right side. the left side is left un-installed for symmetry.
