Licensed User
Shuie's Avatar
FS: 2.4T MFI motor
Good solid running motor, pulled 2 weekends ago. 105k miles, no rebuilds. Needs tensioners rebuilt (kits included, this is why I dropped it) and a new high pressure oil line (hydraulic shop can make you one for $30 with your old fittings). Perfect for 914-6 conversion or would plug right back into another pre'74 MFI 911. I found a 3.2 though, so this really has to go now.
'72 motor, type 911/51, number *6123487*.
Compression was even and leakage test was 8% on the worst cylinder a year or so ago when I bought it. It drips from a couple of spots, but new oil lines will fix all but two of the drips I know about. Oil consumption is fine. I dropped it two weekends ago to rebuild the tensioners (one of them is starting to drag) and have found a 3.2 for it instead. This is a good solid and complete running motor that was in a driving car until two weekends ago, not a core that’s been sitting under someone’s bench or in a barn for 5-10 years.
Upgrades include:
Points replaced with a crane optical trigger (still uses the stock 3 pin CD box), turbo lower valve covers, new Dansk sport muffler, all of the MFI is there and working, new cold start lines. It needs a new high pressure oil hose from the tank to sump since the one on the car needed replacing at the time of the drop. I haven’t done the tensioners yet, but the kits go with the engine.
Auction also includes fuel filter console and the MFI fuel pump. This is everything you need to pop the motor into another car. Also included are my copy of the Bosch CMA manual, my MFI adjustment tools, and a Gunson gas analyzer. If you've ever wanted to delve into the world of Porsche MFI, this is your chance!
Gearbox is a stock '72 915. I cant get to the serial and type numbers, but its out of the same numbers matching car. Shifts the way it’s supposed to, nice, no grinding. Desirable short ring & pinion (7:31).
search my old posts. every problem Ive had with the car has been documented and fixed through this board. shoot me a PM with a phone number if you want to talk about my motor.
Old 04-08-2005, 11:26 AM
I would rather be driving
jpnovak's Avatar
MMMM 3.2...
Old 04-08-2005, 11:36 AM
Licensed User
Shuie's Avatar
Jamie, this would plug rigt into my '72 roller
Old 04-08-2005, 11:37 AM
Licensed User
Shuie's Avatar
I would also trade the whole shebang for a VERY sorted 8:31 915
Old 04-08-2005, 12:40 PM
Licensed User
Shuie's Avatar
bumping..
Old 04-08-2005, 06:03 PM
Zeke's Avatar
Damn......
That's a smoking' deal. (no pun) Sherman, you're killing me. Monday is property tax day and Fri income tax is due. No spare money this month. And nobaody buying any of my stuff.
Listen up you guys, the fuel pump alone is over $400 (way over) and the MFI sells by itself for nearly a grand (yes, T MFI). Yikes! Even a muffler is worth a hun.
Old 04-08-2005, 07:54 PM
Licensed User
Shuie's Avatar
Thanks Milt. Even though its priced like a core, this is a good complete motor. The tensioner rebuild kits go with it. Should be good for a lot more miles after that. The DAnsk is obviously new since the paint isnt burning off yet . The Crane optical trigger and the turbo valve covers are another couple hundred bucks worth of upgrades. Motor runs great. Fuel pump is fine and, yes, they are expensive to replace.
Maybe somebody over on the 914 board wants it for a -6 conversion
Old 04-08-2005, 08:18 PM
Zeke's Avatar
Now you're REALLY hurting me. If I could have found a deal like that, I would still have my race car. But after 2 blown 4 bangers, I was through.
Old 04-08-2005, 08:58 PM
Licensed User
Shuie's Avatar
bump before I ebay it
Old 04-09-2005, 06:23 AM
Licensed User
Shuie's Avatar
eBump
throwing in my MFI tools, gunson gas tester, and my greasy copy of CMA
Old 04-09-2005, 10:52 AM
garner2002's Avatar
what are you aksing for the the engine and complete package?
Old 04-09-2005, 11:42 AM
Licensed User
Shuie's Avatar
$3k + for the complete engine, gearbox, fuel filter console, mfi fuel pump, tensioner rebuild kits, tools, gas tester, and my CMA print out.. or you can bid on it at the ebay link and take your chances. opening bid is $2k + $500 to ship. you can pick it up in 70706 to avoid the shipping costs
Old 04-10-2005, 06:17 AM
BRPORSCHE's Avatar
Send a message via AIM to BRPORSCHE
Head this motor run, sounds great, nothing wrong with it...free bump for a louisiana p-car owner.
good luck sherman with the sell
-Tom
'73 911T MFI - in process of being restored
'73 911T MFI - bare bones
'87 924S - Keep's the Porsche DNA in my system while the 911 is down.
aka "Wolf boy"
Old 04-10-2005, 02:59 PM
Licensed User
Shuie's Avatar
Thanks! I appreciate the help!
Old 04-10-2005, 10:20 PM
BRPORSCHE's Avatar
another bump for a great motor and a great deal
-Tom
aka "Wolf boy"
Old 04-12-2005, 06:04 PM
Licensed User
Shuie's Avatar
deal pending. thanks everyone
Old 04-12-2005, 07:23 PM
Shaun @ Tru6's Avatar
Sherman, if it falls through, let me know. I'm considering a 2.8 for the E and corresponding with Grady, it seems I could use this as a base.
Shaun
Tru6 Restoration & Design
Old 04-13-2005, 05:41 AM
