carburetors vs CIS
I have an 1983 911sc USA with CIS. I am attempting to learn about performance modifications. Through reading Wayne's book it appears that carburetors offer better performance than CIS. Is this true for this motor?
I definitely like the look of carbs compared to CIS. If someone could offer advice reagarding this and is there a resource that outlines how to do this as I cannot find in any of the books I have. Thanks Mike 75 911S |
yes
To really make it right is very expensive as you need carbs, cams, and new pistons (!) You can put carbs on and jet them rich - that works, adds little or no hp, but is a huge improvement in terms of sound and feel. Use the search engine - best is the button at the bottom of the screen you will want SSIs in either case - What are your state's emissions regs?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Do not abandon your fuel injection unless you are totally modifying the car including replacing the entire exhaust and camshafts and will use it for track.
The only performance improvement to be gained with carbs is that they will let you use a more aggressive camshaft, since the CIS will not tolerate this. In installing carbs, you will: A) Spend a huge pile of money on the carbs themselves. At least as much again on other mods to even make them worthwhile. B) Get worse fuel economy. C) Significantly decrease the resale value and originality of the car. D) Decrease day to day driveability significantly. E) End up with something that is much more difficult to troublshoot and maintain. F) Not be able to pass emissions or smog tests. If you want a performance increase and to not suffer the above problems, look at Tony Bitz's EFI conversion. ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
I disagree with most of the information in this post. Carbs are a huge upgrade for the performance of the SC. I race in the Spec 911 class in the Porsche Racing Club on the west coast and here is what you can expect.
With 40 mm webbers, watershields and sport exhaust you will easily get 220 HP and with careful tuning and racing headers/exhaust you can get up to 240. We have one engine with 39mm ports, and euro 9.8 to one pistons that dyno's over 250 and pulls to 7000 RPM. These engines all have stock SC cams and CIS pistons. Now none of these engines will pass smog and of course they don't run as well when cold as a CIS engine but if power is what you want.... -Andy
72 Carrera RS replica, Spec 911 racer |
![]() ianc
240 hp? Did you use an engine dyno? I'd like to see those results.
I agree with a thru F above -- but it is worth it. You can do the pistons & cams later on. Again, your state's emissions laws are critical to this upgrade. IF they won't allow it, you can drop in a 3.6L.
ianc
Well Ian that's a bit extreme. Magic does happen!
(But I always like to see the schematic for the wand....)
Air Medal or two
I would go with aup to date injection sytem b4 caveman carbs....they were better in thir day then cis, but injection has come a long long way baby ......with carbs your limited to other mods, with injection ther are no boundries.
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
I agree - injection will be better ... but the carbs are "only" $3,000 -- a good EFI setup will double or triple that....
ianc
Yes - I'm talking about Motec and the next level down.
Senior Member
I'm going to disagree. With all due respect, and calling nobody a liar, all other things being equal I have never seen credible, or should I say objective and conclusive, evidence that carbs can make any more power than CIS. There is no way that carbs are going to atomize fuel as well as CIS, let alone better. And yes, CIS is less finicky and works more reliably in a wider range of conditions
But there's a caveat. CIS throttle response sucks. Carbs feel like 50 more hp, because of the instant throttle response, as opposed to the "count to three" experience withe CIS. But in my experience, dyno after dyno tells the tale that CIS meters and atomizes fuel just about perfectly. More than a match for carbs, frankly. But again, without the really cool throttle response advantage of carbs. And yeah, carbs look WAY cooler. Also, CIS systems will not tolerate much cam overlap. So yeah, you can build a 270 hp 3-liter with carbs but not with CIS. But that engine will not be as fun to drive around town as my '83 with 20/21 cams and stock CIS.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
ianc
drag racing the short bus
Randy - if you search out "Tony" and/or "dyno results" in the engine rebuild section, he (Tony) put PMO carbs on his "unopened" 3.0 and netted about 240 hp, IIRC.
As for Carbs vs. CIS - you may not have a choice any longer. Upon talking with Tyson at TRE, he informed me that CIS parts, particularly the distributor used for the CIS, are getting sparse and very expensive. Now, if you want to celebrate what, in fact, saved Porsche from extinction, as MFI and/or carbs were becoming inefficient and/or dinosaurs, you will employ CIS. But that's mostly a sentimental reason. If I had the chance to jump on some Webers for a reasonable price, I'd do so. If my CIS suddenly fails, I will also explore the carb route. I'm certain you will gain horsepower. And 20 is not completely unrealstic if your engine is in good shape. By the time you do this modification, however, you should consider appropriate exhaust at the same time. SSIs, '74 heat exchangers, etc. Another benefit of Webers is they are lighter than CIS. |
Didn't think so.. Quote:
What this really boils down to is how you're going to use the car. If you will use it on the track only, then yes, you will be able to use a hotter cam, less restrictive exhaust, etc, and make more power. If you drive the car on the street and want a fun, reliable, driveable, maintainable daily driver, then don't even think about carbs. ianc
Gon fix it with me hammer
oi , nothing inefficient about MFI , and definately nothing dinosaur about it ... the only reason for ditching MFI was the cost , they still kept using it on factory racers for another 10 years or so because it did things that CIS simply couldn't do... how's that for efficient.
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
2) To each their own what anyone drives, how they drive it and how much a PITA they want their car to be.
They weren't; end of story. ianc
