R1200S...More pics
Hugo
Old 11-15-2005, 02:27 AM
Interestingly the new S weighs 213kg's fueled up while the new F800S weighs 210 kg's fueled up...so much for the 'lighter' weight of the new twin
Hugo
Old 11-15-2005, 03:09 AM
Take a look at what MCN claims...
More grunt then a R1 (logical with 1200 cc's) and lighter then a Fireblade?
Hugo
Old 11-15-2005, 03:26 AM
Ride Far - Ride Fast
Dan Alexander's Avatar
Hugo, I think a 1200cc opposed twin being only 3 k more than a 800cc parallel twin is pretty darn good
74 R90S, 77 R100RS, 85 K100RS, 2-87 K100RS
99 R11S
2002 Blue and White GS ... the prettiest
2008 KTM 950 Super Enduro long distance gravel road and general hooligan bike.
Now an R11GS and a 650 Dakar
Old 11-15-2005, 04:17 AM
maybe the gas tank is that much bigger also
99 R11S
Old 11-15-2005, 04:18 AM
Does the shot of the instrument cluster show an ESA button?
Old 11-15-2005, 04:22 AM
Hi Dan,
I meant the F800S with the twin The new R1200S is excellent, but compared with that the F800 is 'heavy'...20 kg's less for that one would have been better...
Hugo
Old 11-15-2005, 04:31 AM
No ESA...some specs
• Air-cooled flat-twin 1170cc power unit with balance shaft.
• Max output increased to 90 kW/122 hp at 8,250 rpm.
• Electronic BMS-K engine management with dual ignition, knock control, two
oxygen sensors, and a fully controlled three-way catalytic converter.
• Light and stable, three-piece frame structure made of steel and aluminium tubes.
• Extra-stiff Telelever with sensitive response and superior steering precision.
• EVO Paralever with extra-light driveshaft.
• Dry weight 190 kg/430 lb, weight in road trim with full tank 213 kg/470 lb.
• Front fairing support made of extra-light pressure-cast magnesium.
• Tail light with 18 LEDs.
• Silencer with tailpipes positioned beneath one another directly under the rear
fairing.
• Aerodynamically optimised, extra-slender body.
• Sports suspension with superior steering precision.
• High-performance brake system.
• New, extra-light ABS (optional) (weight is 1.5 kilos or 3.3 lb).
• Wide range of accessories tailored to the sports rider.
Optional extras available straight from the factory.
• BMW Motorrad ABS (two-channel system).
• Öhlins sports suspension.
• Six-inch rear wheel with extra-wide 190-millimetre tyre.
• Anti-theft warning system.
• Twin-tone paintwork.
• Heated grips.
Special accessories retrofitted by the dealer.
• Paddock stand with an appropriate adapter.
• Passenger seat hump.
• Tank bag.
• Sports bag (small).
• Tinted windscreen.
• Silencer cover made of carbon-fibre-
• Heated grips.
• Supplementary on-board toolkit.
Old 11-15-2005, 04:42 AM
Wow, that black one looks really, really good .... and after reading Ratus's post with the spec sheet, it sounds really good .... think I'll have to go to Toronto on the 5th and see it in person
99 R11S
Old 11-15-2005, 04:49 AM
Weight and Dimensions
Length, overall mm 2,151
Width, overall, with mirrors mm 870
Handlebar width, without mirrors mm 738
Seat height mm 830
Dry weight kg 190
Unladen weight, DIN standard, in road trim kg 213
Max permissible kg 410
Tank capacity/thereof reserve ltr 17/4
Performance
Fuel consumption
90 km/h ltr/100 km 4.3
120 km/h ltr/100 km 5.6
Acceleration
0–100 km/h sec 3.15
Top speed km/h 200 plus
Old 11-15-2005, 04:53 AM
I thought the round button on the left handle bar said ESA but it says ABS. This must be the button to disable abs.
Old 11-15-2005, 05:16 AM
[/B]
Is this the much talked about Teves servo-less ABS ?
Old 11-15-2005, 05:28 AM
The new 2-channelABS doesn't have an integral function or the brake(force) booster. It has a smaller pressure modulator which has a lineair controlled intake valve with a variable opening area creating small pulses which should be barely noticable in the brake lever.
Old 11-15-2005, 05:44 AM
"I see nothing..."
SAHD's Avatar
Hugo thanks for posting the pics.
The black one does it for me. Although I would like to see the corporate colours "weiss-blau" too!
TiM,
2005 R1100S BCR with White PVMs
2009 Aprilia RS125 with GIANNELLI full system, Bitubo shock, etc.
Old 11-15-2005, 05:45 AM
Thumbs up
Thank you! That is one beautiful motorcycle. The black is outstanding, really outstanding. I bet it will quickly become a favorite among the BMW faithful. Just not sure how it would be to ride from SC to Colorado and back like I can do in comfort on the R1100S. But why should it be. If BMW wants to make a pure sport bike that is great too. I just like some reasonable touring capability. I can see one of these in my garage some day.
"Certainty on any matter is not one of the human attitudes the gods admire or tolerate"
A. Cross
Old 11-15-2005, 05:47 AM
...elica rossa...
RoLoo's Avatar
…all those stupid choices you have to make in life…
…I like this 1200 S a lot…
…at home I talk about it a lot…
…I love my wife also a lot…
…once in a while we do a tour together…
…and such goes very well on the 1100 S…
…what to do now…?
…buy a 1200 S, take it out, and leave her at home…?
…stick to the 1100, and dream, and dream…., and dream about this stunning 1200…?
…do nothing…?
…give the 1100, BBPower 1150 cylinders and pistons, modified heads etc.etc….?
…geez ; all those stupid choices…
Have a nice day !
Ron.
R1200S + R1200RT
Old 11-15-2005, 05:50 AM
That's what I said : the new Teves analogue ABS system.
So, the obvious question is : this is the 1st BMW fitted with this system but will it be the last ? Is servo ABS finished ? And if so, why ? 'Progress' or 'Problems' ?
God I would HATE it if HaltenCock was right
Old 11-15-2005, 05:51 AM
Nevermore's Avatar
Grunt than an R1? Funny. Choices are:
a) They have never ridden an R1 or
b) Grunt means between 2000 and 3000 rpm or
c) Typical new bike hype
I'm keeping my R1100S and my R1.
05 Yamaha R1 - Raven
03 BMW R1100S BCR #72
02 MV Agusta F4S
Old 11-15-2005, 06:47 AM
nedsmoto's Avatar
Looks like a Ghezzi-Brian Guzzi from a couple of years ago. Can't say I'm a fan. I like my current S for touring, the sporting side of me has a deposit down on a Daytona 675.
Old 11-15-2005, 06:52 AM
718Rider's Avatar
Send a message via AIM to 718Rider Send a message via Yahoo to 718Rider Send a message via Skype™ to 718Rider
Nice looking bike in black. The big ? - How much will it cost. For 17 large, I can think of a lot of other bike's I'd buy before this one. If they could sell it for 12-14 that would be much more interesting, but I doubt it will come in under 17. Too bad.
Current Rides
2007 R1200S
Silver, Vanderlinde Full Exhaust
Old 11-15-2005, 06:57 AM
