1987 944S 49k orig miles
16valve "S" Dark grey, with linen (light tan) interior, sport seats, cruise, cd, power windows locks mirrors. 48xxx miles are original and the car has a clean carfax. Windsheild is new, and 1430 dollars of maintence was just done in the last two weeks. It also just had the timing belt service 5k miles ago! The car has been
What's been done: New Koni adjustable's on all four corners Timing belt and tensioners wheel bearing Clutch hose fuel filter brake fluid flush clutch flush trans fluid I'm happy to answer all questions. price 6900 Mike mikeferg75(AT)hotmail.com
1975 Carrera Coupe #391 1980 924 11k orig miles 1974 914 2.0 LE Creamsicle 1979 Dodge Lil Red Express 2015 Wrangler Unlimited, and a bunch of bicycles. Last edited by mikeferg75; 01-28-2006 at 08:40 AM.. |
one more pic:
1975 Carrera Coupe #391 1980 924 11k orig miles 1974 914 2.0 LE Creamsicle 1979 Dodge Lil Red Express 2015 Wrangler Unlimited, and a bunch of bicycles. |
Stahlwerks.com
What are the performance differences of the 944s motor vs the 944?
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" |
keep the dream alive! 1988 944 NA (purple) |
Geez, where were you last summer when I was looking for one of these? They're pretty rare and this is a nice color combo, not to mention the low miles. Bump for a very nice looking car.
I believe the 16 valves bumps the HP rating up to 190.
'82 SC pewter metallic Time and Relative Dimension(s) in Space |
I like this car a lot but probably cannot sell my Audi A6 fast enough to get it. I will recommend it to a friend.
A few questions: 1. How many owners, and how long have you had it? 2. Extent of service records available? 3. Reason for sale? 4. Your rating of paint, body, interior, electrics, mechanics (1 to 10; 10 being mint). Thanks, luis g.
Luis "once was - Wickd89" Carrera 3.2 - "Faster, Stronger, Better" -- 2008 Toyota Camry SE V6 (mine) -- 2005 Toyota Sienna (hers) -- 1989 911 Carrera Cabriolet -SOLD |
1. I'm the 3rd or 4th owner I"ll have to double check, I have a clean carfax. It's been a denver car it's whole life. 2. I have the records for the T belt change 5k ago, and the stuff i've done mentioned above. 3. It was more of a impulse buy than anything. I've only owned it a month, 4 cars two of them porsche's is one car to many for me and my family right now. 4. I would rate the cosmetics as a 8, maybe a 7, not a show car, but i'm the very picky concour type. The dash is cracked, you can see in the pics, the front spoiler is cracked, but can be repaired cheap enough, and one tear in the leatherate side bolster, I have a quote from a upholstry shop for 130. couple of small door dings that could be removed by paintless ding removal. 5. electrics, only the sunroof does not work. can still be removed manually 6. Mechanic's are sound, has small powersteering leak, (ball joint ok) and a small coolant leak, them waterpump tested ok under pressure test, but suspect seal. I welcome a PPI. Thanks mike.
Bump
It looks like a really nice car.
I just hope you don't take extra measure to pamper the engine - if you're getting the car for the extra power out of the S engine, you need to rev it high and often. Otherwise the torque at around town engine speeds is about equal to an NA. Don't let it scare you away, though...if you like winding it out, the 4 valvers or turbos make better engines. |
lowered price to 6400.
Mike. 720-890-8790
Bump
Now on ebay... Item number # 4612438522
Mike
