WANTED: factory special tools
all;
WANTED: factory special tools;
P37 for holding the drive shaft when tightening and loosening the castellated nut on the bevel pinion and drive shaft
P135 for tightening and loosening connecting rod screws
P251 for removing pinion shaft stretch bolt
P253 for removing the gear pack at the intermediate plate
P254 for installing and removing the bearing outer ring of the pinion shaft and drive shaft from the transmission housing
P255 for removing the roller bearing from the pinion shaft
P256 for holding the drive shaft when tightening or loosening the hex nut
P257 (2) for removing the roll pin from the differential
P258 for adjusting the pinion shaft
P258B supplementary kit for P258 for adjusting drive shaft
P259 for measuring backlash of teeth
P261 for adjustment of differential
P263 for removing the bearings at the differential housing
P264 for removing the bearings at the differential housing
VW244B for installing the drive shaft seal
VW401 pressure plate support for pressing
VW402 press adaptor
VW405 press adaptor with V-block
VW406 V blocks
VW407 pressure tool
VW409 pressure tool for assembly work on the gearbox
VW412 pressure tool for reassembling the differential
some pix to follow;
most are 911 transaxel oriented. cash outright or trades? possible interest in other tools i don't already have.
thanks for listening.
best
jerry haussler
Old 02-13-2006, 02:28 PM
some pix as scanned from the Special Tools catalog
Old 02-14-2006, 01:07 PM
...and a few more mostly of the VW variety
Old 02-14-2006, 01:12 PM
found a few. still looking for others.
thanks!
jerry
Unclear on the concept ? Let's see if I can help.
1) You are NOT in the "fast lane" and...
2) You are NOT going "fast enough".
**News Flash**
You're in the Passing Lane. Any questions ?
Old 01-22-2007, 12:28 PM
Have you tried Zelenda for the VW tools? www.zelenda.com
You should be able to use a dead gear for P256, and you can make P37 by welding a couple of arms onto a used-up clutch.
Old 01-22-2007, 01:27 PM
MBEngineering's Avatar
HI Jerry, I can have made the P255 for the pinion bearing, the diff setting tool has been superseded to VW385, unless you can find one someone is not using , have you the Epco press for the press tools (vw412) , if not you will have to make a adapter to fit them into your press. VW401 is expens$$ve, I can send you the drawing for the plate, if you have some one to cut them out, from this lot you are going to repairing 901/911 boxes.
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 01-23-2007, 10:47 AM
thanks for the tip re: Zelenda, but it appears they don't have much i'm after. i did make up the P37.
thanks again!
best
jerry
Old 01-24-2007, 06:33 PM
regards mike
hi Mike;
yes, 901 / 911 & 356. the drawing would be great! i'll PM my address.
thanks!
jerry
Old 01-24-2007, 06:36 PM
cycling has-been
bkreigsr's Avatar
Jerry, Here's some tools I have had in the drawer for a while. Interested?
approx 8.25" x 1.1.3"od x .875"id
Bill K
Old 01-25-2007, 06:47 PM
hey Bill...
nice to hear from you. i don't have that manual handy. let me look these up & check their application. if they're 356 oriented, i'm in. PM me some prices.
thanks!
jerry
**News Flash**
Old 01-26-2007, 05:04 PM
cycling has-been
bkreigsr's Avatar
Jerry, might you be interested in this gem?
Old 01-26-2007, 07:16 PM
I have factory 385 setting bar in plastic case missing some trace pins and magnetic pinion target plate like new will send pics if interested. Tom balto. Md . tjl502man@aol.com
Old 01-09-2010, 10:00 AM
email sent.
thanks
Old 01-09-2010, 10:31 AM
