Me like track days
Started with loss of power - down 57 hp
Then 40% leakdown: So let's take a look inside. Heads had been shifting on the cylinders: #3 exhaust valve had 40% leakage: Broken rings.....fairly common: Shop recommends new ARP rod bolts......just in case. Also getting ARP head studs in lieu of the Dilivars from the previous rebuild. What ho? A wobbly rod? OK, let's take it down further: Cylinders got very hot: Rod bearing just about gave up......LUCKY, eh?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno Last edited by Craig 930 RS; 06-26-2006 at 01:09 PM.. |
Me like track days
Just about the worst news one can get.......soooooo close to disaster:
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno Last edited by Craig 930 RS; 06-26-2006 at 01:10 PM.. |
Me like track days
So, that's the bad news.
Time to move on. The parts: 98m Mahles: Long skirt Mahle pi$tons: Ni-resist ringed the cylinders and heads to prevent leakage and shifting (not a good pic): Imagine Auto fuel head, checked/balanced injectors:
Me like track days
Going with 7.5:1 pistons instead of 8.0:1.
After engine break - in, we will working our way slowly upwards on the dyno with: Increasing boost (probably not exceeding .8 bar) AFRs watched closely. Aiming for very low 12s.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Me like track days
Crank did not receive any damage at all other than the scratch in pic above. Needs only a polish.
Heads might be done this week. I pick up injectors tomorrow. Imagine Auto $500 'flowed' fuel head will be here today. K27 Hiflow turbo needs no work and is in great shape.
Me like track days
Soon she'll be back doing this:
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno Last edited by Craig 930 RS; 06-26-2006 at 01:11 PM.. |
Looks pretty icky.
What were the rest of the leakdowns? How about the compression? Could you hear the air escaping out the tailpipe on #3? ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
Me like track days
All other bearing surfaces and leakdown numbers were great.
#3 had the air a-comin' out the pipe, yep. I will try to make this thread as fun and involving as this 24,000 view thread I started in 2004: Brother.....I have seen the light! A 3.6 Varioram...
Me like track days
Injector test rigs and actual test. Injectors look good!
Would you consider reworking the oil passages in the crank? Seems like nos. 2 and 5 (especially 5) get shorted on oil.
Stranger on the Internet
Craig:
Who's testing the injectors? I need to get mine cleaned and tested, and I can't find anyone here in the East. And, what kind of rings are you putting in? Thanks! Pat
Patrick E. Keefe 78 SC |
Me like track days
Rings are the ones which came on the Mahle pistions -
http://www.witchhunter.com/ Local guy working out of a nifty little home shop Oil passages.........damn.....good idea. I'll check -
Me like track days
I intend to use either .8 or .9 bar MAX with the 7.5 pistons (were 8.0, ready for EFI), taking baby steps and working towards low 12 AFRs in conjunction with gradual timing increases on the dyno --- all the while while under the watchful eye of a local wrench and ex-935 Bayside mechanic:
Be careful with creeping up the ignition timing while on the dyno. I did this once and ended up with too much advance when taken to the track. We were doing relatively short pulls which didn't build the same heat as on the dyno.
Matt B '73 911E |
Me like track days
Heh, exactly why I am bringing a seasoned vet along -
Any progress/ideas about the oil passage enlarging?
1987 911 sunroof - just starting out on that slippery slope =-D |
Automotive Monomaniac
Craig,
Did you ever test your oil after changes? Would you have seen the rod bearing failure in the oil analysis? - Mike
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
Me like track days
Additional oil passages are added to the crank with that process -
We cut the oil filter open - and found just traces of bearing 'dust' - so a majority of the metal loss ocurred quite some time ago.
Criag, its great to see you making steps to get your car back together. I hope your luck continues as you shoot for .8 and 12s.
Matthew “Sometimes the questions are complicated and the answers are simple.” |
I didn't want to say anything, being the newbie I am, But did you notice this (circled in red)?
What, if anything can be done about it?
