Air con for early cars
Hi I have a 912 and we are moving to Oz in a few years so i need to get the 912 fitted with AC
Well traveled car 1st Germany-USA Ca-UK Southamtpon-Oz Perth. Any way.. it's *****y hot there and I need AC so I have an AC set up in my 65 car which I will not be taking with me so I am robbing it out that car.. I have the pump, pulley , Rad ( duff ) lines ( old and duff ) controls and Porsche After Factory /Market but it is Porsche air con control unit... how does it all work and I do I make it work...
Too many cars too little time.. |
Search here for Jim Sims excellent explanation of both how the system works and how he installed a new system on a mid-year 911 with outstanding success.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Nice one John..will take a look if any one has this in their favorites list can they post it I will take a look now..
Might even spoil myself and get it working before I go to Oz you know for the very hot weather we have here in the UK :-|
Yes I can see it but it is over a number of posts I will try and take some time to go though it ..
his unit is like the one I have
Is there a web site that any one knows of that basicly discribes how AC works cos I have no idea at the moment and it's a new project for me... we kinda don't need AC in the UK well may be for about 5 hrs in one day in one year!!!!!
If your plan is to use the AC equipment from your 65 and expect it to work in Aus. I'm afraid you will be sweating like a pig. There is a lot of aftermarket AC parts available that can make a AC system that will freeze you out but it takes $$$ and time.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
I haven't installed AC in an pre-69 type 911 but I doubt the '65 911 compressor mount brackets and crank pulley would work with the 912 engine (356C engine?) and I recall a fatigue life problem with the "SC" crank used in these engines. Adding the fatigue loading of an A/C compressor to this crank would at least give me pause. I suspect you need to find the engine related A/C parts from a 356 to install A/C in a 912. The only thing I would consider using from the '65 A/C set-up would be the fender mounted condenser and rock shield (if it has one) but even then the whole system if in good shape may be worth more to someone who wants to restore a '65 911 to period correct A/C. If I were given this project I'd duplicate the 356 engine mount in aluminum and use a '73 or later Porsche 911 factory underdash duct unit and Behr evaporator/blower unit with a modern evaporator in it. I would also use new reduced barrier hose and aluminum hose fittings to help keep the weight and bulk down. Further, I would use a modern condensers and perhaps the very smallest Sanden compressor. See the below link for other links to early Porsche A/C.
http://forums.rennlist.com/rennforums/showthread.php?p=3347575#post3347575 |
912UK,
In a word - don't bother ! You will be spending good money for little result. Ask me how I know! Its well known that all 911/912s up to '86 were not body engineered to accomodate effective air conditioning. Keep your car for non commuter drives and get a Corolla with icy a/c as a daily driver. Cheers, Dennis.
The 914-6 from my 'Lotto'garage has finally arrived. 1971 911S 2.2. 1975 Carrera Targa (ROW) - missed. One of us is fast becoming a valuable antique. |
Bird. It's the word...
Yep, don't waste money. The previous owner of my 69T spent $6000 AUD to set up A/C in the car including a modern (Sander) compressor and extra condensor. It was always crap, and I have now removed it all.
I live in Queensland which is much hotter and humid than Perth, it's just not that bad to drive without A/C. Use the quarter vents to set up a nice flow through and maybe carry a spritzer bottle of water ![]() Seriously don't bother with airconditioning an old 911/912. Save the money for petrol!
John Forcier Current: 68L 2.0 Hotrod - build underway |
Actually, the A/C in the pre-86 911's can be made to work well if the update/refurbishment is done properly. It will cost though: US$1000 to US$4000 depending upon where the project starts from.
cheers for the responce who said I had a 65 911 as a donor car for the AC???
it's another 912 So I have the set up for AC from a 912 for a 912. still intersted in doing the project. Jim do tell me more
It seems as though you are going to fit this a/c. My advise would be to put the condenser up in the left front wheel arch ( about the same place as the later 911's have the oil cooler just on the other side of the car) and fit a thermo fan to it as the fan on your 912 will not pull enough air through it to have any cooling effect. Alternately you could fit the condensor under the front bumperbar so that you have air through it when moving. Somebody else has said it a/c on the early cars is next to useless here in OZ but good luck.
Richard.
Life is not a journey to the grave with a pretty and well preserved body but to skid in sideways, used and worn out saying " What a trip! |
The RennAire systems work well. Pelican sells them here:
http://www.pelicanparts.com/catalog/shopcart/911E/POR_911E_VENTac_pg2.htm#item10 |
Yes good luck with the project, but just to clarify...
My 911 had 2 condensers fitted (one in the left rear wheelarch with fan and one in the rear deck lid), the latest Sander compressor, latest A/C lines, and new gas. This is arguably the best set up for the older cars. Useless ![]() The other thing to consider over here is that we are not allowed by law to use R12 (the good stuff), we can only use R13a which is not as efficient. This compounds the problem. Seriously, get your cars over here and at least do a summer without A/C before committing to the expense. If you think it's truly unbareable, then by all means do it. PS, You'll love Perth, it's a beautiful place.
Did you end up doing this "little" project? How'd it go? Moved to Perth yet?
MichaelJapp '71 911E |
no not yet but still collecting the parts
off to Perth for 2 months soon and then we will make a final decision from there.
Just be glad you're not moving to Darwin !!!
Its about 35C here every day with humidity up to around 70-80% ![]() ![]() Hope to see you on TYP901 soon Let us know how you go. Cheers
'74 RS 3.0 Replica Porsche 968 Clubsport SOLD '70 911E Bahia Red SOLD '71 911 S/T Replica 2.3 Twin plug BEAST SOLD
