Porshe “1974 IROC RSR”
My 2005/06 project. 1983 911SC built RSR style mainly as a DE car but not too far from street legal. (Would have to add a cat, remove the front half of the cage and add the stock belts which I probably have. ) This 911 is a blast to drive. It looks, handles, stops and goes better than I could have expected. Car is located in New Jersey. Looking for $30,000.00. You can email me at giuffrec@aol.com
Thanks-Chris Street/Track – Freshly Built appox 1000 miles since build. Porshe “IROC RSR” bodied 911, Built on 1983 911 SC Tub. Sunroof and tray deleted, Interior stripped to paint. Front wells stripped bare, etc. Aprox. 2300 lbs Factory Steel Turbo Front Fenders and Steel Rear flares GT Racing Front and Rear Bumper GT Racing Front Deck GT Racing Billet RSR small rear grill Front and rear tie downs Fiberglass rear reflector delete panel Chrome Flag mirrors r&l Clear Stone Guard -Hood, Fender lights surrounds and H4's Recaro Racing Seats Simpson Harness’ Safety Devices Cage New H4’s RS Door Panels, limited interior trim “Café Racer” style New headliner Momo shift knob Momo wheel w/ quick release mechanism Voostek Pedal Set RSR Foot Rest Custom Foot Board covers Llyod mats Black w/silver Engine 3.0 L Euro engine. Freshened including valve guides, tri- cut valve job, new rings, 964 cams SSI’s Dansk 2 in 2 out stainless muffler Wevo semi-solid stainless motor mounts MSD Ignition, Master Blaster Coil Magnacore wires Large Front Mounted Setrab Oil Cooler Transmission Rebuilt 915 w/ limited slip Wevo semi-solid stainless trans. mounts Rennshift Shift New Shift Bushings Wevo PSJ Suspension 22 Sway Away fnt / 29 rear Sander hollow-plugged torsion bars Turbo Tie-Rods Bilstien Sport fronts / Bilstein custom valved rears (Jack French Spec.) Raised Spindles Tarett front and rear hollow sway bars Elephant: Poly bronze control arm bearings Low friction control arm mounts De-cambered Ball Joints Offset mono ball camber plates Bump Steer Kit Sealed Rear Mono Ball kit Polybronze spring plate bearings Strut Brace Wheels 3 Piece polished Fuchs wheels, 9.5 x 17 w/ 275 front – 11 x 17 rear w/315. Goodrich street rubber Chrome Plated Steel Lugs Brakes 928 / 993 front and rear brakes. VCI package w/ turbo front and Carrara rear rotors Pagid pads, 23mm turbo master cylinder
For all those asking I will E-mail and post addl. pics this weekend.
Thanks-Chris
Looking for: 1969 911T - Engine - 6196603 & Gearbox - 7196742 1969 911S - 901/13 Gearbox - 7195559 |
[img] |
ttt
S
Seasonal Bump
For all those looking for more pictures and for the just curious here is a link to some of the project pics.
http://pictures.aol.com/galleries/giuffrec
bump
Still Available. $30k OBRO
Ready to Go!
bump
Looking for: 1969 911T - Engine - 6196603 & Gearbox - 7196742 1969 911S - 901/13 Gearbox - 7195559 Last edited by Stophos; 05-12-2007 at 06:14 AM.. |
Boop
Bump for $500.00 Buy It Now Shipping Assistance & Free 11x17 Lindsey Fuchs
bump
bump
Buy It Now for $28,500.00
Looking for: 1969 911T - Engine - 6196603 & Gearbox - 7196742 1969 911S - 901/13 Gearbox - 7195559 Last edited by Stophos; 05-12-2007 at 06:16 AM.. |
