Crankshaft cross drill
Hi Guys,
I am about to embark on a monster 3.5 l motor. I know this motor will spin between 7200 & 7700 rpm, based on the cams etc. I want to cross drill the crankshaft (3.2l 74.4m), but am concerned as to the possibility of weakening the crank. Is there any reduction in the strength of the crank with the cross drilling, and would the cross drilling need to only go to the oil passage in the crank, or all the way to the other side of the journal. You advice is appreciated, as I don't want to make a mistake. By the way, I will be using the GT3 oul pump. Thanks in advance. |
This cross drilling of 911 crankshafts seems to be a recent development. I could be wrong but I don't think Porsche did this on any of it's race engines including the 800 HP 935 engines. I think this is a solution in search of a problem. So far I haven't heard of any crankshafts breaking due to this mod however.
I don't know for sure but I suspect if you matched the oil holes that are already in the number 1 and number 8 main journals you'd get what you want. I don't have a crankshaft in front of me right now to see if there are 2 holes or 1 in these journals. You also have to groove the main bearing to supply oil to the holes you are drilling. -Andy
72 Carrera RS replica, Spec 911 racer |
We've been doing this since 1979 as thats the only effective way to ensure sufficient oil to the center of the crank at high RPM. Porsche didn't do it for a long time and suffered #2 & #5 rod bearing failures,... ![]() Properly done, it doesn't affect the durability of the crank.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Agree'd. The center drilling of the crank is a mod well worth doing. Although, I would not rev the engine past 7200 without other mods accompanying the center drilling. I think Steve would agree.
South Shore Performance (Facebook us) Freeport NY FIKSE Dealer BBS Dealer |
Good show Steve. I always enjoy reading your posts. I am sending you a pm
I stand corrected. Thanks for the information.
-Andy
Navin Johnson
Pic of a center bearing being grooved
finished bearing
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
| Tags |
| cross drill crank |
