Writer/Teacher
Stumped!
Are these nuts holding the bolt onto the exhaust manifold/crossover pipe housing, or are they physically part of the housing itself?
If they are nuts, I can't get them to budge, even with my impact wrench... if they are part of the housing, I'm at even more of a loss because I can't imagine for the life of me how someone would be able to get a wrench of any kind onto the tops of the bolts on this assembly...
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
Cars & Coffee Killer
I seem to recall that one side of the crossover pipe had either studs or welded-on bolts.
Get yourself a flexible-neck ratcheting wrench and try the other side.
Writer/Teacher
Looks like this will wait for another day...
winter-hater club member
on my car, they are nuts.
At least on the cars i've seen they are always nuts. Looks like you've already got penetrating oil on them- or maybe thats motor oil? I use Kroil penetrating oil which works like a charm on rusty stuff. I have to get an impact gun on the nut with 4-6" wobble extension and a wrench on the bolt head to break some of them loose though.
-Gabe -black 1988 924s, 944 turbo sway bars, LSD, gunmetal phone dials-- SOLD to some people who cannibalized her -1987 MR2 ---ONLINE REP FOR RADMACHER PORSCHE SERVICE IN TUCSON--- |
^second the kroil. best stuff ever. mine came apart with a craftsman u-joint socket and a box end wrench.
Writer/Teacher
i tried for hours to get them loose and not a single one would budge. Liquid wrench, ratchet extensions, impact wrenches, nothing would work. I think I will bring it to a shop at least just to get the bolts loose...
Just thinking out loud
S'OK! The best out there. Green aerosol can w/ a shamrock on it, IIRC.
Hard to find though. Found. http://www.shamrockspecialties.net/products.htm No affiliation, just satisfied.
83 944 91 FJ80 84 Ram Charger (now gone) Last edited by mattdavis11; 06-05-2007 at 10:49 PM.. |
You may have to get a nut cutter. Small one I would think as there is little room at that location.
An air grinder might reach most of them. Either a drum bit or a cut off wheel.
Ended up just getting a small air grinder/cutter in there and digging away till they came loose.
87 924S 107k (miles) yellow 1969 Firebird Coupe (Full frame off restoration.) 98 BMW 740i 2020 Subaru Outback and 2019 Crostrek. |
Politically Incorrect
RE: impact wrench
- what was the tank outlet pressure (turn up to max) - what was the impact wrench setting (turn up to max) - has the wrench been oiled lately (betcha can't remember when) I did the shocks on my wife's car recently and I couldn't get the strut to steering knuckle bolts to budge (BMW E34). Once I addressed the above three items, the bolts came right out.
Edek '87 924S '91 535i Last edited by onZedge; 06-06-2007 at 11:38 PM.. |
Maybe there isn't any thing wrong with the nuts, but the problem is your girlie arms. I've helped a couple people that had buggy whips for arms get the same bolts loose before. Just a thought.
ur right, it wasn't...
..lil funny though.
