That got your attention, didn't it ! If you have noticed that your oil temps are creeping up and you haven't changed your fuel filter lately, do so. The fuel filter on my SC had not been changed for about 18 months and oil temps had been running hotter this summer than last summer (210 vs. 190). A couple of days ago I noticed a gas smell and tracked the leak down to the bottom connector on the fuel filter. Hmmm, he said, high pressure fuel leak and higher engine temps! Maybe the filter has gotten partially clogged and the engine is running lean? Maybe the clogged filter is causing the high pressure fuel leak? So off to the parts store, buy new filter and install. No leaks, and in urban traffic with the a/c on the oil temps now are back at the 190 mark.
20 degrees for $20.00 !
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
I see, I should put the cool-collar on the fuel-filter - got it.
19 years and 17k posts...
Excellent!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Or, you could put the Cool Collar on your neck and then YOU would be "cool"
Thanks for the tip
![]() I have a new filter sitting on the shelf.
John D. 82 911 SC Targa-Rosewood 2012 Golf TDI |
Would a bad fuel filter cause crazy reading on the fuel guage?
Frank 1980 SC Cab Conversion (sold) 1974 914 2.0 RIP rear ended Looking for a 996 Silver Cab 2002-2004 |
drag racing the short bus
Good to know. I'll look into it with my next oil change/valve adjustment.
Thanks.
The Terror of Tiny Town |
When I changed my 4 year old fuel filter out I had to lean out the mixture by almost half a turn to get it to run where it used to.
83 911SC Targa Everything I say is my personal opinion, and has nothing to do with my team. |
