Go Back   Pelican Parts Forums > Porsche Forums > Boxster & Cayman Forum
Author of "101 Projects"
Wayne 962's Avatar
Boxster Project 55: Brake Rotor Replacement
Anyone got any questions on Project 55 - Brake Rotor Replacement for your 986 Boxster, 987 Boxster, Cayman, Carrera 996, or Carrera 997?
Here's a back link to the original article: Pelican Technical Article: 55-BRAKES-Replacing_Brake_Discs
-Wayne
Old 12-31-2009, 04:10 PM
Removal of the caliper is accomplished by unbolting the two hex bolts that mount it to the arm (yellow arrow).
Does anyone know the exact size of these hex bolts? I'm thinking of buying only this socket instead of a full set of hex sockets.
Old 10-11-2011, 07:31 AM
10mm hex - I found it at this write-up, which also recommends using a manual impact driver to remove the locator screw:
Boxster Projects | Brakes | Change Rotors
Old 10-13-2011, 06:09 AM
