Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
550SPYDER's Avatar
FYI - DIY rear Deck Lid Shocks and Hood Shocks
Alright, I know it's not rebuilding a G50 or pulling the motor, but just wanted to post this in the event that anyone was interested in the fact that one person with two hours can install two rear deck lid shocks and two front hood shocks all within earshot of a 6 year old who by the way loves to ask her mother what "new words" mean when she hears them from dad...
Here is my set up.
a. 1982 930
b. factory engine pad installed - just to make it "more" challenging...
c. Large Andial Intercooler
d. AC Compressor
Things you will need
1. 1/2 inch PVC Pipe cut to length to support rear lid and hood at their maximum expended position based on the throw of the shocks
2. small needle nose pliers
3. medium needle nose pliers
4. hood shocks
5. Smaller set of Vicegrip pliers
Rear Deck Lid -
Starting from the passenger side - real straight forward
1. Place PVC on motor mount bolt and Whale Tail Grill Bolt on Drivers Side
2. Passenger Side - remove the shock point connected to the whale tail - one clip, one pin
3. Passenger Side - remove the shock point connected to the firewall
Drivers Side - much more obstructed can only use your fingers to remove clip and pin on fire wall
1. Place PVC on motor mount bolt and Whale Tail Grill Bolt on Passenger Side
2. Driver Side - remove the shock point connected to the whale tail - one clip, one pin
3. Driver Side - remove the shock point connected to the firewall
HINT - Make the PVC a little longer than you need and use the excess length as a BOW to raise and lower the Deck Lid while trying to align the pins
Front Hood –
(HINT - make sure that you do the lower pin first when reassembling the shocks and make sure that you have the upper portion free floating inside the two cross members before you connect the lower pin, shock and clip)
Passenger side is so easy I am not even going to go into how to replace that one. HOWEVER, the Drivers side lower socket is a &^%$ing pain in the A@@
Here is what I came up with after you remove the drivers side shock - take a small pair of needle nose pliers and working from the wheel well towards the center of the car, pre-insert the pin just enough for the pin to intrude into the cross member. Then carefully insert the lower part of the shock being careful not to dislodge the pin (Good news is that there isn’t really anywhere for the pin to disappear to so you can always find it if it comes out (and it will come out)). After you have the shock in the socket between the cross members and the pin pre-inserted in to the hole closest to the outside of the car, wiggle the shock while applying pressure on the pin with the tips of your fingers to insert the pin into the mounting hold in the shock. Now, here comes the tricky part. After you have the pin in the mounting hole in the cross member and then through the hole in the shock, there is no longer enough play in the shock OR room for your hand for you to push the pin any further with your fingers, so using the friction provided by the shock hole and the pin, use the shock to align the pin with the inner most cross member hole and guide the pin through the inner mounting hole – it took me three tries to get this done.
Alright there you have it, hope this helps someone.
___________________
Ryan
2003 996
1982 930
Old 03-24-2008, 09:41 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
