Loose mount?
Hi All,
When recently getting my oil change and tires rotated, I was told that the crossbar that holds the engine up (mount?) needs to be replaced. This makes sense because as I drive around I hear a jiggling noise in the hood of the car and squeaking, as if something is loose (especially when I hit bumps). Is it called the engine mount? And how prevalent is it that i get it fixed ASAP? Money is tight. Thanks ALL! Pete |
Author of "101 Projects"
Yes, this is the engine mount. You should be able to purchase the mount (here at Pelican), and then jack the car up on jack stands, raise the engine with the jack, and replace the mount...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
