Go Back   Pelican Parts Forums > European Car Forums > VW/Audi Technical Forum
Rebuilding a 1.8t
Hey all having fun rebuilding a 1.8T and doing some fun coating. In my engine builds I have found the rustolem X2 spray paint works surprisingly well on engine parts and deals very good with heat.
going for around 250 to 300hp in this engine ones done.
1982 924 *Audi V8 Swap In Progress*1985.5 944 NA *3.0L 16V swapped* 1987 944 Turbo *3.0l 8V*.
1987 944 NA 1991 944S2 2001 VW Passat, *Built 1.8T* 1985.5 944NA Sold to younger brother
1983 944NA Gave to my Dad for being Awesome.
Old 02-24-2020, 09:18 PM
1.8t update
1.8t is coming along nicely. Ran into one issue, the timing chain tensioner is messed up. so the cams are locking. I have one on order. Other then that. engine is turning out great!
Old 03-14-2020, 07:37 PM
pretty stuff.
Brian Lamberts
Tucson AZ
Old 03-19-2020, 03:28 PM
Originally Posted by Brian in Tucson View Post
pretty stuff.
Thank you. will be done with the build this weekend
Old 03-20-2020, 04:44 PM
More progress on my 1.8t rebuild
This has been a lot of fun and will look great going back into our Passat. I will be running a full external oil cooler set up as well.
Old 03-24-2020, 09:17 PM
1.8t update
basically got the 1.8t at a done point. I am awaiting my Header, Cat, and Hot housing the come back from Jet hot. then Engine can be installed.
Old 03-25-2020, 09:54 PM
1.8T is installed
1.8t Is installed. ^_^
went Single mass flywheel too. worth it!
Old 04-19-2020, 08:47 PM
Good Progress
Old 04-24-2020, 08:32 PM
Good clean up accomplished
Got her all cleaned up. Next just waiting on the ECU to arrive. then can start her up!
Old 04-26-2020, 05:13 PM
