Go Back   Pelican Parts Forums > European Car Forums > VW/Audi Technical Forum
Rescuer of old cars
Arne2's Avatar
VW Mk1 Caddy comes to my garage
Just picked up a rough '81 VW Caddy (pickup) with a '92 Passat 2.0 16 under the hood. Going to be a long haul, but I've been there before. Here's some prior projects:
Before and after:
"Honestly now, did you spend your youth dreaming of someday owning a Nissan or Mitsubishi?" - Porsche ad from early '90s
1972 911T coupe
Priors - '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 08-25-2020, 05:30 PM
Rescuer of old cars
Arne2's Avatar
Here's the Caddy:
1972 911T coupe
Old 08-25-2020, 05:34 PM
Rescuer of old cars
Arne2's Avatar
Hasn't been on the road in at least 5 years, and been a no-start issue for the last 2. Spent some time today and had it running for a bit, need a proper fuel pump relay.
It's a bit rough...
1972 911T coupe
Old 08-26-2020, 05:52 PM
Administrator
Luccia at Pelican Parts's Avatar
I love these things! I saw one in person a little while back that was completely restored. Looking forward to following your progress!
Old 09-01-2020, 02:35 PM
Rescuer of old cars
Arne2's Avatar
It should be a fun little truck when I get it done. The 2.0 16v is about twice the power of the original gas 1.7, and almost 3 times as much as the more common diesel pickups. It also has a close-ratio 5 speed with 3.94 final drive from an early GTI. So it will be surprisingly quick.
I got it running about a week ago, although not 100% yet. The Motronic ECU is apparently running in limp-home mode. So the AFR is way rich, and there is no ignition advance at all. Indications are that it may have at least one bad knock sensor. So no driving it yet...
1972 911T coupe
Old 09-10-2020, 07:33 PM
Rescuer of old cars
Arne2's Avatar
Timing belt today...
1972 911T coupe
Old 09-16-2020, 04:37 PM
Rescuer of old cars
Arne2's Avatar
While waiting on parts, starting to pick away at cosmetics.
Before:
After:
1972 911T coupe
Old 10-16-2020, 04:45 PM
Rescuer of old cars
Arne2's Avatar
1972 911T coupe
Old 11-21-2020, 09:50 AM
