Go Back   Pelican Parts Forums > European Car Forums > VW/Audi Technical Forum
Angry Audi 200 Turbo
I am wondering if anyone knows how to remove the steering wheel on a 89 200 Turbo?
Old 12-04-2009, 12:51 PM
Did you check behind the wheel. There are usually holes for the air bag bolts . Get the air bag out then the 1 steering wheel nut...
Old 12-17-2009, 09:18 PM
Thank you for your reply, but I don't think my car has airbags. I know that there is no indication of airbags anywhere. I have looked behind the wheel for something, but I have found nothing......very confused by the whole thing. I can get the column cover off and that's as far as I get....
Cheers
Old 12-23-2009, 04:40 AM
Paradigm Short Shifter
Send a message via AIM to UrQuattro Send a message via Yahoo to UrQuattro
You pull on the horn cover pad and it will pop off. You might have to pull pretty hard. Do it at each corner of each spoke and then you'll get access. I believe that it was 1990 that the 200 got airbags. Is it a quattro? Just curious.
Michael
Old 12-25-2009, 09:49 AM
