Pelican Parts Vendor
Yes, once all the welding and cutting is done it will be disassembled, painted and then reassembled. I think it's called a "dry build phase".
Dry Building: Why It Makes Life Easier - Super Chevy Magazine
Paul Eddleston BRAID Wheels USA The last Wheels You'll Ever Need http://www.pelicanparts.com/catalog/SuperCat/0812/POR_0812_BDYWHL_pg3.htm#item11 |
Storage Unit Rally Build - Week 15 (Quick Update)
I'm back to working on the fan mount. You may remember that our beautiful afterthought of a fan shroud would not allow us to fit the actual fan as it interfered with the frame rails because we didn’t think it through. So, we ordered up six of these fan mounting brackets and went to town. ![]() ![]() The fan is quite weighty so we thought some vertical hanging type mount would be a good idea. We cobbled one together. ![]() That’s better. ![]() Fits too! ![]() ![]()
Works really well for the Fan. I will need to do the same thing for my 924 with the 4.2L Audi V8 to give me more space. Thanks for the Idea!
1982 924 *Audi V8 Swap In Progress*1985.5 944 NA *3.0L 16V swapped* 1987 944 Turbo *3.0l 8V*. 1987 944 NA 1991 944S2 2001 VW Passat, *Built 1.8T* 1985.5 944NA Sold to younger brother 1983 944NA Gave to my Dad for being Awesome. |
Glad to have helped.
Week 16 of the Storage Unit Rally Build
It's been cold so we felt inspired to hook up the heater controls. This week we learned all about “Bowden Cables”! These clips are hard to find new but we found some. ![]() And dug out the rest of the system. ![]() ![]() The control sliders went in easily but hooking up the cables and clamps was a bit fiddly. Surprisingly satisfying once done though. ![]() ![]() ![]() ![]() ![]() Now we just have to figure out how to direct the air from the heater box to various body parts and bits of glass. ![]()
Week 17 of the Storage Unit Rally Build: A Sharp Intake of Breath
We’ve been back and forth on what to do about an intake system for the car for ages. We’d like to have our cake and eat it too but we just can’t see a way to get there. This is what we’d like to have: ![]() ![]() As used on the works rally cars. It looks iconic and sucks air from the high pressure cowl area where, conveniently, there are louvers in the hood above for that very purpose. There are a few problems with this. Firstly we have a MAF sensor to incorporate in the intake track, ideally in the stock location as we have an aftermarket U shaped intake tube that houses connections for all kinds of other bits and pieces that we need. This really doesn’t mate up to that. ![]() Secondly, if we did this it really would have to be made of carbon Kevlar to pass muster and making one from scratch would be very expensive and time consuming. You can, in theory, buy one but we’ve heard it’s of dubious quality and it still wouldn’t mate to our MAF sensor. We tried prototyping an alternative route to the cowl that goes down the bulkhead to an existing 3” hole before doing a 180 into the passenger compartment and back up through another existing hole in the cowl. We think we could terminate this into an oval shaped pancake filter with a lid. It would probably work and we think we could make it look half decent but our fear is that it would just look like a poor substitute for the original. ![]() ![]() ![]() ![]() We could just whack a bloody great cone filter on the end of the MAF sensor and declare “job done” but there are a few problems with that too. It would be sucking air from right next to the turbo and also be right under the hood louver that lets hot air out of the engine bay and, not great, water in. So we dismissed this too. Here it is mocked up with a small filter. ![]() ![]() ![]()
We looked at modifying some OE intake boxes but they don’t seem to be suitable either.
![]() So we’ve settled. Settled on another U bend with a cone filter behind the headlight. This is not under the louver so should stay dry and it gets a good cold air feed from the grill and light surround. We also think we can shield it from the engine bay quite easily and, although it is a bit rigged it will hardly be visible so it doesn’t matter if it looks it. ![]() ![]() ![]() If nothing else it will do to get the car running. Maybe we will revisit this later, or not.
Very good Choice and Idea on that intake for the Turbo. Keep that air a cool as possible facing forward like that. Going to make a really cool induction noise too.
Thread Tools | |
Rate This Thread | |
