VW motor in my 73 911
Hi ijust bought a 1973 911 with a blown 2.4L and i wanted to put a vw motor in it. Its more reliable and cheeper since the car isnt stock anyways. If you coul help me whats the best motor that will hook up to my tranny and how much modification will i have to do and is it costly?
Yeah this section is pretty slow.
Try posting your question here... you should get a quick response: http://www.shoptalkforums.com/viewforum.php?f=19&sid=602da6508aac4078f03ed2d8e31 64032
Jake Often wrong, but never in doubt. -99 E300TD - converted to vegetable oil -90 4runner - dieselicious project www.jakesgarage.ca |
Pretty straight forward swap.
CHECK this page Just need a throttle cable adapter of some kind, an engine mount bar and a way to seal up the engine tin- if you care that much. I don't if 74' had a 915 tranny or not... Make sure your clutch fits the input shaft of teh tranny before anything. Bob O You should be able to sell the 911 parts for enough to set yourself up pretty good too!
If it aint broke.. ... ... .fix it anyway. |
yes there is a 915 tranny in it. Is it still possible or is it just a costly headache
GOT TURBO..
wouldnt recommend it
your doing a backwards swap and end up with a head ache. yes it is cheaper in the long run,but harder to maintain on a reliablity issue. the look of it on the end,doesnt look right.
jimmy d. @ porsche mobile works |
HI just find a 912 that is bent at the front and take the engine and box out , it should have a 411/412 VW engine in with all the fittings.
regards mike |
