kcope's Avatar
Unhappy Dim Low Beams
Hi All
When I first purchased my 911 in May I noticed that my low beams were very dim (H1s) but the high beams were fine. I swapped with headlights from one of my Triumphs that I knew worked fine. Same problem, highs fine, lows suck. So I bought the
H4 set up. Yup you guessed it, Highs fine, lows a tiny bit better but still unacceptable. At least now I can see the where the low beams hit the road.
Where should I start? I have already cleaned and tightened the ground connections even though I know that's not the problem. I also plan to install relays on both high and low beams over the winter.
Any assistance would be much appreciated.
TIA
Ken Copeland
70 GT6+ KC78784
70 Spit FDU84919
70 GT6+ KC81551 (Ok so I like 70s)
71 Porsche 911T
00 Chevy Pick UP
Old 09-11-2002, 10:55 AM
scottb's Avatar
I had a similar problem years ago with another (non-Porsche) car. I found that the ground to the headlights wasn't sufficient or had degraded. It's possible you have a bad ground cable, so you might consider replacing that. I ended up adding a separate ground wire to the dim headlight on my car, and it solved the problem.
Good luck.
1984 Targa
Old 09-11-2002, 10:58 AM
A few quick thoughts - does the high beam indicator light in the dash work correctly (lit up brightly when the highs are on; completely off when the highs are off)? When I first put my H4's in I had the wires on incorrectly; the highs were great, the lows were very dim and the indicator light was always on (either brightly or dimly). If I remember correctly, with the tabs on the light forming an inverted U, the left one was ground, the top was low and the right was high. I remember a recent post here with a picture that can confirm this. Just a longshot guess - if you have that many Triumphs you by now no doubt have a strong background in auto electrics (I have a 74 Spitfire myself).
The stalk switch for high/low/turn indicators is also a usual suspect for problems.
Argo
88 Targa
Old 09-11-2002, 11:11 AM
derek murray's Avatar
H4 below; terminal # 1 - earth (brown), #2 - low (yellow), #3 - high (white)
'70 911S 1002938
'70 Ducati Mark 3D 350
Old 09-11-2002, 12:50 PM
Yup, that's the one.
Argo
88 Targa
Old 09-11-2002, 01:36 PM
hilandscott's Avatar
Question location?
Would this be near the bumper or inside the headlight bucket?
'78 SC Euro turbo conversion (track days) SOLD
'89 928 S4 (daily driver)
'10 XC70 (family car)
http://www.pelicanparts.com/gallery/hilandscott/
Old 09-11-2002, 04:05 PM
kcope's Avatar
Hummmmmmm I think that it wouldn't hurt to check the battery ground. the headlight grounds are seperate so a bad ground would only affect one side.
It also looks like I might have the wiring wrong (see pic) but I don't get a high beam light on low and it would seem like my beams would be reversed. I'll switch that too and see what happens.
As you can see I didn't have any plugs when I bought the car I have since put plugs on.
Any other ideas?
Ken Copeland
70 GT6+ KC78784
70 Spit FDU84919
71 Porsche 911T
00 Chevy Pick UP
Old 09-11-2002, 05:13 PM
kcope's Avatar
pic
oops heres the pic
Ken Copeland
70 GT6+ KC78784
70 Spit FDU84919
71 Porsche 911T
00 Chevy Pick UP
Old 09-11-2002, 05:31 PM
scottb's Avatar
Lotta gunk in there. I'd take it apart and clean the contacts with some emory cloth and/or a small file. I think it's a good place to start, at least.
1984 Targa
Old 09-11-2002, 05:53 PM
subscribe
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 04-17-2011, 11:45 PM
I'm having a similar problem. I'm thinking of adding electrically held contactors that are controlled by the original headlight wiring but adding direct wiring from the main 12 volt buss to the headlights direct. I'm sure this has already been done.
Lindy
Tell it like it is or don't tell it at all.
Old 04-18-2011, 06:22 AM
Under the radar
Trackrash's Avatar
Location: Fortuna, CA. On the Lost Coast near the Emerald Triangle
I had the same problem.
Check you fuse block. Check if your lowbeam fuses are hot.
The problem on my car was the riveted connector on the back of the fuse block had a small amount of corrosion and thus resistance. The heat just about destroyed the fuse block.
I had to solder the rivet to ensure a good electrical connection AND add a RELAY.
Gordon
___________________________________
'71 911 Coupe 3,0L outlawed
#56 PCA Redwood Region, GGR, NASA, Speed SF
Trackrash's Garage :: My Garage
Old 04-18-2011, 09:10 AM
Your wiring doesn't match the image. Could this be the cause?
Steve B.
1972 911t
1999 328is
Old 04-18-2011, 09:23 AM
AKA SportsCarFan
FastCarFan's Avatar
I have always thought that my headlights - both low & high - beams are marginal at best. A couple years ago I had a problem with my low/high beam switch & my high beams were on regardless of stalk position. What's funny is no one noticed!
My commute involves mostly 2-lane highways & at that time of year (fall) I had the headlights on both driving to & from work. I drove the 911 for 3 or so days & not one person flashed their lights at me because my high beams were on!
Doug Miller
1988 Guards Red Carrera
Old 04-18-2011, 09:32 AM
HarryD's Avatar
Doug:
Sound like you turn /hi beam control switchis bad. Check this thread (turn signal switch quick fix pictures) for a DIY fix or replace it. You should also add headlight control relays to protect the turn signal/hi beam switch.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-18-2011, 09:43 AM
I just went out and looked at my wiring and it was just like Kens image. I changed it to the H4 picture and it's a lot better. Both high and low have the same intensity.
Lindy
Old 04-18-2011, 10:10 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Contact Daniel Stern.
I have the H1's and his bulbs, literally day and night compared to anything on the market.
Here is my thread: Daniel Stern Review
I have literally tried everything short of going HID: Sylvania Silver Stars, PIAA's, 100Watts ... None compare to Daniel's Bulbs. In fact I moved the left over Silver Stars and PIAA bulbs over to the Hi-Beam's, the lo-beams are much brighter.
No affiliation to Daniel Stern.
'85 Carrera Targa
PCA/POC
Old 04-18-2011, 10:48 AM
AKA SportsCarFan
FastCarFan's Avatar
Originally Posted by HarryD View Post
Doug:
Thanks, but it was fixed a year or so ago. That is exactly what the problem was.
Doug Miller
Old 04-18-2011, 06:35 PM
HarryD's Avatar
Sorry, thought you were describing a current problem.
Harry
2020 MB E350 4Matic
Old 04-18-2011, 06:41 PM
Banned but not out, yet..
RSBob's Avatar
Sounds like you are low on electricity. I would buy a 12 oz bottle of 12 V ZAP at Napa and add to your electrical system.
After you are done, (finding a legit solution) please post your results.
Old 04-18-2011, 07:36 PM
