Flushing out non-BMW coolant
I just bought a '97 328iC and discovered that it has non-BMW coolant in it. I'd like to replace what's in it with Genuine BMW antifreeze. Do I need to make sure that the old coolant is completely flushed out? If so, how do you do this? Can you just pour distilled water through the system?
Thanks for the help! |
Author of "101 Projects"
Short of pressure washing / flusing the entire system, it's nearly impossible to get all the old fluid out. The *only* way I know of to do this is to take the entire system, empty it, then fill it up again, run the car for a short while, and empty it again. This will get almost all of the old fluid out, but is pretty costly when you use the Genuine BMW coolant.
In reality, it probably won't matter too much if there is other coolant in there. Just to be on the safe side, I would indeed do what you suggested - empty the system, fill it up with distilled water, let it run until it gets hot (with the heater on full blast), then empty it out again, nd refill with the BMW coolant. That is the procedure I'm currently doing on my 5-Series... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thanks Wayne.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
