tmow11 (guest)
Guest
Posts: n/a
I have a 1984 318i, I swapped a 1985 318i motor in, before and after the swap this problem was going on. The car idles high 1500 rpm in park and won't kick down to low idle 800-100 until I shift into gear. Everything was working great, then this happen...did the swap and it still is being weird. I've changed the ICV, compression on new motor is great, no hissing/vacuum leak. What's going on?
This post was auto-generated based upon a question asked on our tech article page here: BMW E30 3-Series Idle Speed Troubleshooting (1983-1991) | Pelican Parts DIY Maintenance Article
Old 07-29-2016, 05:02 AM
Nick at Pelican Parts's Avatar
Most likely a faulty idle control ecu. Very common.
- Nick
